Home > Technical (L322) > Rear airbags, front dropped.
J2B
England 2010 Range Rover Vogue TDV8 Ipanema Sand
2010 (model year2011)TDV8 ,Had suspension fault flashing on dash, passenger side rear air bag dropping over night consequently drivers side front was high up, after levelling it I did plug it in said offside front level sensor, replaced rear airbags now the front has dropped and will not raise, no suspension fault flashing now. I have ordered a replacement sensor just want thoughts if I'm on the right track obviously I'll plug it in again after sensor replacement.
Thanks in advance.
Post #650503 11th Dec 2022 8:51pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Did you go through the height calibration procedure ? TDV8 4.4 2012
Post #650520 12th Dec 2022 1:56am
J2B
No I haven't as of yet, I'll put the new sensor on then go through it, thanks.
Post #650576 12th Dec 2022 3:43pm
Ramblin Man
I’d suggest trying to calibrate first. I learned that all sorts of errors occur if the sensors are unevenly adjusted. I recently had an suspension failure whilst driving and went through an arduous replacement of the sensor only to find that it was most likely a calibration issue. If the sensors are out side the ECU calibration range or if there is too much difference between sensors on opposite sides of the car the system throws all sorts of warnings. Mine dropped onto the bump stops.
See here https://www.fullfatrr.com/forum/post648179.html#648179
And here https://www.fullfatrr.com/forum/post648291.html#648291
trying a calibration first costs little effort and may save a sensor replacement task if successful. Keep the adjustment range less than 250 on any one sensor or the ECU throws an error.
If the calibration doesn’t work then change the sensor. TDV8 4.4 2012
Post #650612 12th Dec 2022 9:29pm
J2B
Thanks very much for your pointers very much appreciated, finding time to do it now Thumbs Up
Post #650621 12th Dec 2022 11:33pm
J2B
Managed to get the front end up, no thanks to the iid tool wouldn't connect to my phone again.
took it for a very short drive suspension fault appeared 30mph ect as the front dropped,turned off restarted engine select suspension height required on the dash, saying its in access height when it clearly isn't, air pump is working overtime so called it quits before it gets over heated, I might be Censored in the wind here but im going to change the front level sensor and try that before attempting to try to connect the iid again, frustrating.
Post #651182 19th Dec 2022 8:10pm
Phoenix
What is being shown on the 4x4i screen? are the heights plausible?
Don't worry too much about running the compressor, there is overheat protection built into the control parameters. Sometimes it needs to run for a while to build up the volume & pressure required to lift a couple of tonnes.
Post #651183 19th Dec 2022 8:13pm
J2B
thanks for your reply , screens just got range rover and a flashing button at the moment another issue so cant access that first thing i would have looked to be fair just to see, need to get the iid tool to connect.
Post #651185 19th Dec 2022 8:46pm
Phoenix
OK, have you looked at the height sensors all round to make sure they're all in the correct position and not gone 'over centre' during the repair operations? Also that all the plugs are fully latched in place on them? I appreciate it might be difficult with it dragging it's @rrse on the floor like a dog with worms!
Can't help with IID, I don't use one.
Post #651186 19th Dec 2022 8:53pm
J2B
im thinking with the rear passenger side sitting arse down and front drivers up in the air i think its gone over, will get on it over the next few days
Post #651420 21st Dec 2022 11:07pm
J2B
I did get this sorted in the end early March this year, 2 x new complete front legs, as one burst,was the original legs, another new front level sensor oem this time and a bit of fettling thanks to Martin at Dartford Transmissions.
Post #681450 29th Dec 2023 10:25pm
