Home > Technical (L322) > 2012 L322 Preheater Remote
Steved1806
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Hi,
The cold mornings are awful. Does anyone have a pre heater remote for sale for a 2012 Range Rover L322 Westminster?
I know it’s a first world problem, but it would be lovely
Thanks
Post #649837 4th Dec 2022 4:37pm
mjdronfield
Have you checked you have the receiver in the boot? If not, the remote won’t do anything.
You can still set it to come on at a set time using the screen… whilst you sort a remote….
I’m guessing it’s a T91 you need, with ON and OFF on the buttons?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #649851 4th Dec 2022 6:28pm
garyRR
Need to be careful with 2010-2012 model runs because the remotes look the same but there is a different part number for different chassis marks, to save yourself wasting money on one that won't work.
There was a topic on this recently:
https://www.fullfatrr.com/forum/post644977.html#644977
You need to get the exact remote according to your chassis (of which there are 3 versions), otherwise it won't work. Ordering from main dealer with your VIN will probably be less hassle for not much more money (I think they're just over £100).
An alternative solution is to hook up a GSM gate opener to a timer switch, this will enable you to use your phone to activate the Webasto, but does involve some technical knowledge and a little bit of wiring.
If the remote is missing, there's a good chance the FBH might not have been run in some time. The fuel pumps are known to corrode and cause problems. Try firing it up from the infotainment system (ambient temperature will need to be below 5 degrees, so test late in the evening). If it doesn't work, you may also need a new fuel pump for it (not the end of the world and readily available on ebay).
Can be swapped over in 10 minutes with no more than a socket and extension:
https://www.fullfatrr.com/forum/topic64152.html 2015 Range Rover Autobiography 4.4 SDV8
Post #649874 4th Dec 2022 9:49pm
Steved1806
Thanks mjdronfield and GaryRR. I should check I have the heater in fairness, as you have suggested.
I assumed I have one as the option for the timer is on the infotainment system. Never tried it but going to test as if it is there there is a fault with it I’ll need to fix that first.
Wasn’t convinced when i read about the mobile app and switch as I don’t fancy cutting the wiring up. I’ll likely get the wrong wires!
Many thanks for you advice, it’s really helped
Post #649878 4th Dec 2022 11:24pm
garyRR
Yes start with triggering it from the audio system when the temperature is below 5 degrees. The orange light on the fan knob should start flashing to indicate the ventilation system is running. You should then hear a clicking from the rear diff area of the car, plus a quiet whirring sound from the front left wheel arch (plus the smell of diesel burning).
If the system fails to run for whatever reason, there's most likely a fault e.g. no clicking indicates the fuel pump has failed and the system then switches off because there's no fuel feed. 2015 Range Rover Autobiography 4.4 SDV8
Post #649879 4th Dec 2022 11:32pm
Steved1806
Spot on GaryRR, I’ll try that this week thanks
Post #649882 5th Dec 2022 5:14am
mjdronfield
You will definitely have the fuel burning heater fitted, as it’s standard fit. It’s whether you have the facility to remote start it, but as above, need to check it working ok from being set by the screen first.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #649887 5th Dec 2022 9:01am
mjdronfield
Just seen this. Bit of an insight if nothing else….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #650616 12th Dec 2022 10:10pm
Warkman
We have the remote, but the battery is flat.
Opened it up, expecting a cr2031 flat battery, but it’s a small tall battery
Anyone know what this battery number is\/ 2012 FFRR
Post #650903 16th Dec 2022 12:48pm
Discotigger
The battery is a CR1/3N, best to get the Duracell batteries as the cheap ones don't cut the mustard.
Link for battery type off of the bay of fleas:
https://www.ebay.co.uk/itm/112764514587
Post #650906 16th Dec 2022 1:17pm
Warkman
Many thanks, ordered one.
Post #650908 16th Dec 2022 1:20pm
mjdronfield
See you’re sorted now….
This is in the manual if you need the blurb….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #650916 16th Dec 2022 2:57pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
I have a 2012 L322 Supercharged petrol LH Drive/North American model - is there a remote start option for these, or am I better off going through the aftermarket? 2012 Supercharged L322
Post #650931 16th Dec 2022 6:41pm
mjdronfield
You will need to have the fuel burning heater fitted to start with. Wasn’t standard fit on petrol models in the UK, but may have been in the US.
If it’s there I believe you just need to have at least a receiver in the boot and remote.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #650932 16th Dec 2022 6:55pm
mjdronfield
https://www.fullfatrr.com/forum/topic40586...t=retrofit
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #650933 16th Dec 2022 7:09pm
