Home > Technical (L322) > 2012 L322 Preheater Remote |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
Have you checked you have the receiver in the boot? If not, the remote won’t do anything.
4th Dec 2022 6:28pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
Need to be careful with 2010-2012 model runs because the remotes look the same but there is a different part number for different chassis marks, to save yourself wasting money on one that won't work.
4th Dec 2022 9:49pm |
Steved1806 Member Since: 04 Sep 2020 Location: Newcastle Posts: 15 |
Thanks mjdronfield and GaryRR. I should check I have the heater in fairness, as you have suggested.
4th Dec 2022 11:24pm |
Yes start with triggering it from the audio system when the temperature is below 5 degrees. The orange light on the fan knob should start flashing to indicate the ventilation system is running. You should then hear a clicking from the rear diff area of the car, plus a quiet whirring sound from the front left wheel arch (plus the smell of diesel burning).
4th Dec 2022 11:32pm |
Spot on GaryRR, I’ll try that this week thanks |
5th Dec 2022 5:14am |
You will definitely have the fuel burning heater fitted, as it’s standard fit. It’s whether you have the facility to remote start it, but as above, need to check it working ok from being set by the screen first.
5th Dec 2022 9:01am |
12th Dec 2022 10:10pm |
Warkman Member Since: 05 Dec 2017 Location: Warwickshire Posts: 13 |
We have the remote, but the battery is flat.
16th Dec 2022 12:48pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The battery is a CR1/3N, best to get the Duracell batteries as the cheap ones don't cut the mustard.
16th Dec 2022 1:17pm |
Many thanks, ordered one. |
16th Dec 2022 1:20pm |
See you’re sorted now….
16th Dec 2022 2:57pm |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 67 |
I have a 2012 L322 Supercharged petrol LH Drive/North American model - is there a remote start option for these, or am I better off going through the aftermarket? 2012 Supercharged L322 |
16th Dec 2022 6:41pm |
You will need to have the fuel burning heater fitted to start with. Wasn’t standard fit on petrol models in the UK, but may have been in the US.
16th Dec 2022 6:55pm |
https://www.fullfatrr.com/forum/topic40586...t=retrofit
16th Dec 2022 7:09pm |
