Home > Technical (L322) > Charging issue? 4.4TDV8 |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
No hurry mate, just would be interesting to know. |
10th Dec 2022 9:20pm |
Yep, I have same driving patterns. Only difference is, that mine never had a problem starting, even with the old battery with sometimes less than 8V of cranking voltage. Also never had any random messages on the screen from low voltage. Guess the relay and the cable are not the problem on every 4.4TDV8 then. |
11th Dec 2022 5:28am |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
What are you chasing then? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
11th Dec 2022 7:58pm |
Just interested, if 3s cranking time is normal for 4.4 TDV8. No concern, just interest. |
11th Dec 2022 8:33pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Well it sounds a long time, I'm expecting to see a 4.4 TDV8 in the next few weeks so I can time that as well as mine (3.6 TDV8), mine 'feels' like 1-1.5s at most. |
11th Dec 2022 9:08pm |
Mine seem instant. Have you tried waking the car up then starting? as in push the starter, let it POST then start with Brake + start switch? Have you also explored possible fueling issues etc? Specially if it is turning over but not starting. Mow many K's have you got on the car? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
11th Dec 2022 9:28pm |
Fueling seems ok and car has 238 000 kms.
11th Dec 2022 9:45pm |
Mine has done 205k
12th Dec 2022 7:16am |
Like I said, 10 seconds, when it is -20C, today it is -15C outside and GPs were on about 6-8 sec.
12th Dec 2022 7:37am |
You have triangulated your answer then. You may consider DEFA type engine preheater (240v) or do a summer benchmark SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
12th Dec 2022 8:59pm |
Cranking time is the same regardless the time of year or temperature. No answer yet, since the question was, what's the exact cranking time on other 4.4TDV8-s. |
13th Dec 2022 9:29am |
ok bit of an observation, my car jumped into life soon as I pressed the starter today after parked up for 24hrs. No POST procedure here etc. This used to be a struggle in the past SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
14th Dec 2022 10:06am |
Intersting, seems like it cured itself then. |
15th Dec 2022 6:52am |
The mod has made the difference. I also have a new alternator, starter and new relays.
15th Dec 2022 7:18am |
