Home > Technical (L322) > Charging issue? 4.4TDV8
Page 4 of 5 <12345>
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
No hurry mate, just would be interesting to know. Smile
Post #650426 10th Dec 2022 10:20pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
ok been away for a week, came back to a SOC of around 12.2 (pre travel SOC @12.6) Car started first go with reported CV of 9.25v and LV warning.
All depends what you are trying to achieve really. I can now park the car for a week and still able to drive away, pre relay mod this would not be possible for me.
Note:
- I only do short trips around town with everything on, so no real opportunity for optimised SOC.
- I have installed a small piggyback relay that energises the starter relay directly from battery. The small relay has no problem engaging which is spliced into the trigger wire north of the connector at the air box SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #650436 11th Dec 2022 2:22am
kokamagi
Yep, I have same driving patterns. Only difference is, that mine never had a problem starting, even with the old battery with sometimes less than 8V of cranking voltage. Also never had any random messages on the screen from low voltage. Guess the relay and the cable are not the problem on every 4.4TDV8 then.
Post #650437 11th Dec 2022 6:28am
ffrr14
What are you chasing then? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #650499 11th Dec 2022 8:58pm
kokamagi
Just interested, if 3s cranking time is normal for 4.4 TDV8. No concern, just interest. Smile
Post #650501 11th Dec 2022 9:33pm
Phoenix
Well it sounds a long time, I'm expecting to see a 4.4 TDV8 in the next few weeks so I can time that as well as mine (3.6 TDV8), mine 'feels' like 1-1.5s at most.
Post #650507 11th Dec 2022 10:08pm
ffrr14
Mine seem instant.
Have you tried waking the car up then starting? as in push the starter, let it POST then start with Brake + start switch?
Have you also explored possible fueling issues etc? Specially if it is turning over but not starting.
Mow many K's have you got on the car? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #650510 11th Dec 2022 10:28pm
kokamagi
Fueling seems ok and car has 238 000 kms.
Haven't tried to switch the ingnition on first, good idea.
Also you're in Sydney, no wonder yours starts instantly, you have always summer mate. Very Happy Probably your glow plugs get hardly any use, they're the ones pulling a lot of current just before start. When under -20 degrees outside, they are on for about 10 seconds.
Post #650511 11th Dec 2022 10:45pm
ffrr14
Mine has done 205k
POST the car and check how long the GP light stay on for. Split second on mine in winter, summer barely comes on.
Just recored a video and I will benchmark that with mine. Same vintage car with similar distance etc etc SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #650522 12th Dec 2022 8:16am
kokamagi
Like I said, 10 seconds, when it is -20C, today it is -15C outside and GPs were on about 6-8 sec.
In summer GPs are not used unless it's a cold morning.
Post #650524 12th Dec 2022 8:37am
ffrr14
You have triangulated your answer then. You may consider DEFA type engine preheater (240v) or do a summer benchmark SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #650609 12th Dec 2022 9:59pm
kokamagi
Cranking time is the same regardless the time of year or temperature. No answer yet, since the question was, what's the exact cranking time on other 4.4TDV8-s.
Post #650635 13th Dec 2022 10:29am
ffrr14
ok bit of an observation, my car jumped into life soon as I pressed the starter today after parked up for 24hrs. No POST procedure here etc. This used to be a struggle in the past SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #650707 14th Dec 2022 11:06am
kokamagi
Intersting, seems like it cured itself then. Very Happy
Post #650809 15th Dec 2022 7:52am
ffrr14
The mod has made the difference. I also have a new alternator, starter and new relays.
So it should read, "I had the starting problem before I made the mod" Replacing alternator, starter and new relays did not. Right now there is no starting lag what so ever. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #650811 15th Dec 2022 8:18am
Page 4 of 5 <12345>
