Home > Maintenance & Mods (L322) > Main ventilation fan maintenance |
LowB Member Since: 23 Jan 2021 Location: Farnham, Surrey Posts: 35 |
The main ventilation fan in my 2011 Vogue SE is squealing when going round right hand corners, so presumably the bearings are on the way out.
12th Dec 2022 7:56pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Try lubricating first I would. Remove pollen box under bonnet and you should see it in inside the exposed holes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
12th Dec 2022 9:22pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If it's noisy when turning corners, that would suggest the impeller is catching on the casing, which in turn would suggest there is wear in the bushings - which can only be cured by replacement. It may be temporarily 'fixed' if you can get some viscous lubricant between the bushings and the motor shaft, but that would only ever be a temporary measure. |
12th Dec 2022 10:07pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1477 |
Temporary is perfectly fine by me Phoenix if it means the difference between doing the job in sub-zero temperatures or a lovely and warm spring day 2015 Range Rover Autobiography 4.4 SDV8 |
12th Dec 2022 10:10pm |
Plastic edges are definitely sharper in the cold...
12th Dec 2022 10:22pm |
My intention was to use some spray on lithium based grease, given it's pretty heavy duty.
12th Dec 2022 10:35pm |
I know the one you mean - it's not that! HHS 2000 is the one, had to look it up for my own curiosity.
12th Dec 2022 10:45pm |
Thanks for the insight and suggestions. I’ll take a look via the pollen filter box and try lubricating it with something suitable. 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
13th Dec 2022 6:35pm |
LowB - bomb down to Petersfield and I'll give you a hand on my drive Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Dec 2022 10:34am |
I took out the pollen filter assembly today and greased the fan bearings as best I could (didn't realise how tight the spot is, and needs the engine running or battery disconnected to stop the flaps closing).
2nd Jan 2023 3:43pm |
Gary - will you do the "dashboard cut out" route to make it easier to remove and replace? Saves a lot of hassle I'm told.
3rd Jan 2023 8:38am |
Looks like it will be the cut-out method, given the plastic to be removed is just trim and doesn't support anything. Removing the entire interior, steering wheel and crossbeam seem far too excessive / greater potential to break something.
3rd Jan 2023 12:32pm |
Your write up will be invaluable for others Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Jan 2023 12:45pm |
