Home > Maintenance & Mods (L405) > DPF - Cleaning as a preventative measure
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
In the next few months, I will do my first oil change as the car is now under an extended warranty. As part of that work, I'm thinking of cleaning the DPF. I have watched some YouTube videos on this and started reading about this on the internet. If it is as easy as they show in the videos.
Question: Is this a good preventative measure? or if the active Regens are working leave well alone?
The process is adding cleaner via a pipe into the DPF and then running the car with something to catch the mess when it comes out of the exhaust. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #650297 9th Dec 2022 5:34pm
cass
If the DPF isn't causing any problems I'd be tempted to leave it alone, My L322 has done over 120K miles and never had a DPF fault and never had any additional cleaning.
Post #650299 9th Dec 2022 5:44pm
Yep, if it ain't broke, don't fix it... walk away..... Thumbs Up Pete
Post #650301 9th Dec 2022 5:53pm
Kot
Agree with the comments from cass and Haylands, why would you? if you were regularly getting the amber warning light I would be concerned. 2018 SE SDV8 4.4 Byron Blue
Post #650305 9th Dec 2022 6:38pm
DrRob
Madness. Leave it alone if it’s working ok. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #650319 9th Dec 2022 8:07pm
luxmoggy
Duly noted... I will leave it alone... SDV8 AB MY 2020
Post #650324 9th Dec 2022 8:29pm
