Home > Technical (L322) > Iphone to aux |
Neil E Member Since: 05 Jan 2010 Location: North West Posts: 56 |
Hi all,
19th May 2011 3:24pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35115 |
afaik the aux is for output only, not input.. |
19th May 2011 3:28pm |
christ! no wonder then!
19th May 2011 3:31pm |
not sure but there is loads on this subject here somewhere .. |
19th May 2011 3:33pm |
thanks I`ll take a look through forum. MY10 3.6 TD V8 Autobiography
19th May 2011 3:35pm |
You can input via the aux I am pretty sure as I have done so with my Blackberry sounds files.... |
19th May 2011 4:14pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Sorry scarey, I have to disagree - the 3.5mm aux "input" socket in the rear centre panel on D3,D4 RRS & FFRR is for audio input. Looking at the link posted about the cable it appears to have two phono connections? How have you converted this to a single 3.5mm jack plug? For the wife's D3 we bought this: http://www.amazon.co.uk/Kensington-33429EU...B0011UK2HE Works perfectly and charges the iPhone AND has a remote control I would check that your cable is the right one as it doesn't look compatible to me AND as a rule, never use the headphone socket on an iphone as the audio source - It has very low line output and therefore low volume through the cars audio system Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
19th May 2011 4:19pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
The 3.5mm RSE jack on my 2006 FFRR is for aux in and allows you to play music through the speakers. The red and white line-in inputs only allow you to play sound through the RSE.
19th May 2011 4:20pm |
apologies all, i haven't got this feature so i wasn't sure... |
19th May 2011 4:29pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6361 |
You can play video through the phono ports in the RSE panel, from your iPod for example. However it only plays on the REAR screens, not the front centre screen.
19th May 2011 5:26pm |
ZZT Member Since: 02 May 2011 Location: NJ Posts: 3 |
The real problem is that mp3 players are designed to drive headphones. Headphones don't need the same signal level as the AUX input. If you are going to use a headphone output, you'll most likely need some type of in-line amplifier. Google "portable headphone amp" or "Sound Shocker Pro" and you'll find lots of info. Almost all need some sort of power (battery or car plug-in) except Sound Shocker. |
20th May 2011 1:33pm |
Sorry but I disagree.
20th May 2011 1:42pm |
duka Member Since: 11 Jan 2011 Location: uk Posts: 145 |
I'll have a check on my lead, I bought it from ebay for £2.99 & can plug my iphone through the rear 3.5mm aux socket & it plays music without hassle. |
20th May 2011 2:48pm |
I think we may be straying from the original post which was a concern specifically regarding an iPhone audio out and the correct cable - I was just pointing out that an iPhone has a very low output gain from the headphone socket and because of this the headphone socket is not really suitable to connect to the aux input in Land/Range Rovers! You have to use the main connector at the bottom of the phone which has a much higher audio output gain which works perfectly. Apple have obviously designed their phone that way "Health & Safety" for the ears I guess But without testing the headphone output of another make of phone I have no way of proving whether you could consider it a design fault of the car. I do know that on my old 2003 FFRR when I swapped out the radio tuner for the BMW version with aux input and you had an adjustable input gain from 1-6, this is not possible on newer FFRR models. Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
20th May 2011 4:12pm |
