Home > My Range Rover > My 06 SC rust repairs pt1, 2 and 3
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
This follows my posts about my range rover, but I cannot for some reason upload any photographs, so I started a new post.....
See https://www.fullfatrr.com/forum/topic55392-75.html
To make it clear I have never done any body work, welding or fabrication before, one thing I am not is a panel beater, so please be kind when criticising Bow down
So a quick review of where I started
This was under the cill near the jacking point to the right.
The leading edge of the arch looks a little crusty...
So cut that all out
I then made these, ignore the bottom right as I remade that later.
Picture of the parts made for the inner wheel arch from the out side
And the inside
Obviously whilst preparing for welding, needs more fettling.
I them made the under cill repair panels. I did this in two parts as the jacking point projects below a straight repair panel. Have a look at this post https://www.fullfatrr.com/forum/topic65295.html
To press the drain channels I made a simple tool to mount in my vice..
Part 2 will show the repairs in place........ Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #650136 8th Dec 2022 4:11am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
That's going to be a great help when I come to do mine in the spring. I think that I'm going to have a bigger hole though Shocked
Post #650141 8th Dec 2022 9:08am
bigbo
New cavity access point ready to be welded
Welded and primed
Under cill panel welded in place
A shot showing the jacking point, I made a mistake here and allowed the panel to part company from the inner jacking point leaving a gap between the two panels.. I will cut, persuade it into place and reweld once I get some better weather
Now the end panel to close the cill
The final part to be fitted is the arch repair panel. Again I am waiting for better weather.
Pt 3 to follow
David Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #650476 11th Dec 2022 6:02pm
bigbo
Part 3
Finally I have managed to get out onto my car. Its either been a cold, flu or freezing weather that's stopped work. Feels like I have been ill or cold since Christmas.
After lots of fettling of the repair panel I got to this
Before fitting I drilled 2 9mm holes in the inner arch for 3 reasons, first I could insert a rod to help manipulate the repair panel into place as I welded. Second I could insert my borescope to check for pin holes after welding and finally to inject cavity wax.
I stitch welded slowly to keep the heat down but also to enable me to adjust the fit.
I finished the welding using stiches and then ground back. A couple of additional welds were required to fill in pin holes.
Ended up with this.
Finally I warmed up an aerosol of high zinc primer and warmed the panel with a hot air gun and sprayed two coats of primer. It will stay in primer until the warmer weather arrives so that I can apply top coats and lacquer.
I am really pleased with myself as before I started this I couldn't weld and had never beaten any metal or fabricated any body repair panels.
Next job is the rear of the arch and then the offside!
MG TF 2003
Post #657286 21st Feb 2023 12:46am
Sandyt
Well done you its great when you achieve stuff like this Thumbs Up Thumbs Up Thumbs Up
Post #657296 21st Feb 2023 7:55am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
nice work well done you!
welding on car panels is hard to master and beating panels is harder still.
look forward to the end result. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #657297 21st Feb 2023 8:11am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
you have done a good job so far bigbo for someone like me that's welding on a weekly bases looking good . you have done the worst part shaping and welding now just take your time on finishing and grinding the welds and making good with the filler work etc. just make sure that the water outlets on the sill are free and can drain out any water in the future . well done to you Thumbs Up new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #657322 21st Feb 2023 11:24am
bigbo
Thanks all for the comments. Much appreciated.
The welds that are covered by the cill cover and wheel arch liner wont be ground down, I dont see the point as long as they are fully protected with paint and cavity wax then I am happy.
All the cill drain slots are clear but will be checked again after the next injection of cavity wax.
The outer arch repair needs very little filler as I was very careful to align the panels as accurately as possible, but there is a slight depression right on the edge at the top of the repair panel. Filler at this point is likely to fail so I may apply some weld to top up.
Back in the old days this would have been done with lead, but that's a skill too far!
MG TF 2003
Post #657412 22nd Feb 2023 4:03am
oggy
old saying what the eyes can't see the heart can't greave about. i am afraid no good for me could not sleep at night knowing I had a visible patch behind the sill covers. i do mine a bit differently so you would not know that anybody has been there. new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657433 22nd Feb 2023 11:16am
bigbo
Oggy, yes I understand your position and in many ways I am the same.
But I need to get my car on the road as soon as I can, I miss driving it!
Had it been an area that's visible then I would have made the repairs invisible.
Maybe when I get round to doing the base coat/lacquer I will have a change of heart.
I now have to get it through its MOT so I need to get the handbrake working next, I can then take it off SORN and get back on the road.
MG TF 2003
Post #657516 23rd Feb 2023 12:54am
oggy
you are doing a cracking job bigbo that's just me. just say I use a lot of the u-pol raptor coat its a 2k item and covers well and a good solid coating they use it for truck bed coatings but is good for the sills new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657566 23rd Feb 2023 1:42pm
bigbo
Thanks Oggy much appreciated.
Never looked at U-pol products other than those in Halfords and other stores. Had a look on the U-pol website and I have to say the safety sheet is a little scary, might kill you, might give you cancer etc think I might give it a miss, I only have diy protection.
MG TF 2003
Post #657575 23rd Feb 2023 2:49pm
Fatboy Slim
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Top job that Thumbs Up
Post #657717 25th Feb 2023 10:05am
