Home > Maintenance & Mods (L405) > L405 Clonking
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
L405 Clonking
Hi, Guys, I read on here recently that someone was getting a clonk from the rear when turning right at low speed and it was due to something to do with the rear axle/diff, it fills a bit like a CV joint but does not continue clonking when travelling forward.
Was there mention on here of a JLR notice to fix it, if so can anyone tell me where to find it?
Thanks, in anticipation.
Post #650085 7th Dec 2022 1:09pm
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi ya,
I had it, had to have a bulletin update as its a known issue 2019 L405 SV Autobiography
Post #650087 7th Dec 2022 1:35pm
SVAuto_Man
LTB00906v6 - Twin Speed Transfer Case Judder
Some owners might experience the below symptoms that are specified in a UK LTB.
The symptoms can occur before or after a transfer box oil change.
The LTB is:
" LTB00906v6 - Twin Speed Transfer Case Judder "
" A customer may express a concern that a judder is felt from underneath the vehicle when using steering input at low speeds, for example turning left or right at a junction. This technical bulletin has been updated due to a change to the warranty section, parts section, condition summary and service instruction. "
If you present your car to a LR Main Dealer with judder symptoms, they might suggest a transfer box double flush, road test and software update. Our car displayed these symptoms (3.0 TDv6). The procedure was recommended and resolved the issue. The LR Main Dealer applied no charge for the procedure.
The symptoms can be the subject of an LR warranty claim.
If LR AU Warranty declines the warranty claim, the MD can raise a case for LR to cover the cost via LR CRC. 2019 L405 SV Autobiography
Post #650088 7th Dec 2022 1:36pm
Tinman
Hi, SV_Auto,
Thanks for your input good to know, my car is into JLR next week for mot, it has an extended warranty so should not be an issue getting it fixed. Thumbs Up
Post #650097 7th Dec 2022 3:21pm
SVAuto_Man
Make sure you tell the bulletin etc, my dealer was lost for a week until I found out about it lol 2019 L405 SV Autobiography
Post #650098 7th Dec 2022 3:24pm
