Home > Maintenance & Mods (L322) > Lower temp thermostat mod
markturner
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Hi, i am trying to find out where to buy one of these, found some older threads but the links in them dont work......Is this still a good thing to do ( Can you simply remove the thermostat instead bearing in mind the likely useage and temperatures here in the SE of England..?)
Thanks
Post #649993 6th Dec 2022 4:01pm
cass
What's the problem that you're trying to fix?
Post #649994 6th Dec 2022 4:07pm
markturner
Hi, not a specific problem, had read this was a good modification to do, as teh engine runs very hot as standard.......
Post #650000 6th Dec 2022 5:16pm
I think you will find that applies to the BMW M62 4.4 PETROL V8 in 2002-5 fatties, not the diesel, diesels run too cold if anything...!! Thumbs Up Pete
Post #650011 6th Dec 2022 6:50pm
pcourtney
Pete is right, I had the temp mod ( lowered to 88 degs ) on my petrol V8 BMW engine 2004 - and it worked wonders, one of the best mods ever - still running today and reccommned this to everyone who has the BMW M62 engine
Post #650039 6th Dec 2022 9:21pm
garyRR
You've got a 4.4 TDV8.
I'd be minded to say if it's not broken, don't fix it, and you're potentially opening yourself to problems, with the ECU reading the engine is too cold and trying to compensate.
The engine operates at such low revs, unless there is a fault or lack of cooling, it will always run relatively cool in comparison to other engines. 2015 Range Rover Autobiography 4.4 SDV8
Post #650046 6th Dec 2022 10:00pm
mjdronfield
Yes, the fuel burning heater is needed to get the TDV8 warm faster, don’t go cooling it down. As Pete says, what you have read is for the petrol 4.4.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #650047 6th Dec 2022 10:08pm
markturner
Excellent, thanks for the advice!
Post #650074 7th Dec 2022 10:39am
