Home > Technical (L322) > Height Sensors help pleaee
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
So, I have put my 04 into a local indie with suspension issues, He has said, height sensor which I thought, problem is this he has one from ebay with a 3 pin plug and mine has a 6 pin plug?? does this resonate with anyone? Thanks
Post #551582 24th Apr 2020 4:35pm
Yep, your model has a 6 pin connector!
Specify VIN/Year/MY when ordering .
Post #551593 24th Apr 2020 5:57pm
Rosco
Thanks Joe, not sure why he has had this issue !!
Post #551633 25th Apr 2020 9:51am
IIRC that happened on mine, I got one from Ducky Dan and it only had three wires, the old one had six, I asked and he said the old one had been superseded. I fitted it and it worked fine..!! Can't see why it would need six wires when it is just a variable resistor like a petrol sender... surely only needs a couple of wires to work...!! Pete
Post #551689 26th Apr 2020 9:53am
Rosco
Pete, thanks, are you saying he can use the 3 pin one then? cheers Thumbs Up
Post #551719 26th Apr 2020 12:56pm
Seems like things have moved on since I needed a height sensor.... .
Post #551726 26th Apr 2020 1:30pm
Rosco
I will have the conversation tomorrow with the indie and report back, all you can find online say fitment to 02-12 so we shall see Thumbs Up
Post #551729 26th Apr 2020 1:42pm
See here on Island 4x4
https://www.island-4x4.co.uk/suspension-pa..._3756.html
Browse the list you will find "Six Pin Type" for Front and Rear (you didn't say which) .
Post #551743 26th Apr 2020 2:49pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Mine through up suspension fault yesterday, fault code for left front so had both front wheels off today for a look see, unbolted from suspension arms and checked the readings on the foxwell while moving sensor arm up and down both doing more or less what I expected to see so back together been round the block and fault not come back just have to see how it goes and mine has three wires on left front and six wires on right front.
Post #551763 26th Apr 2020 5:45pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I attempted replacement of my right rear height sensor today but had to abandon the job after a couple of hours toil.
The screws which mount the sensor to the mounting bracket are just spinning without loosening so I can’t get them out.
I suspect the brass inserts in the sensor are rotating in the sensor mounting…. I can feel a sort of “notching” as the screw rotates. The screw heads are still good without any rounding.
I’ve put some deblock spray on and left overnight
I’m guessing loads of people on here have replaced height sensors.
Any advice or tips on how to proceed ?
UPDATE: today I spent a truly joyous three hours lying under the car with a junior hacksaw cutting the heads off the sensor mounting screws whilst trying not to damage the bracket. I was finally able to use a rotary file once the heads were gone and then to lever the sensor free from the bracket when the heads were filed flush. A total pig of a job!
New sensor ready to go on first thing tomorrow morning once the new coat of Dintrinol has dried. So I hope it solves the fault otherwise it will be a connector/wiring issue.
I was planning to do both of the rears at the same time but funnily I’ve gone off that a bit! TDV8 4.4 2012
Post #649576 30th Nov 2022 9:03pm
mjdronfield
Same happened to me when I did a front one. I had already unbolted the bracket from the car to change it. In the end I found some bolts in my tool box that threaded in to the new height sensor ok, so I literally just needed the bracket. Ended up cutting the plastic on the old sensor to get to the brass insert, which I could then grip to get the bolt out and the bracket off. I pulled the actual sensor off the insert before that…. 20 min job ended up being rather longer….
Rang LR up for a price on the bracket…. £170 odd…..
I soaked it in WD40 overnight but I think that just enabled the insert to spin in the plastic more 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #649577 30th Nov 2022 9:12pm
Jamesh7216
I had the same problem on my car, I just cut the head of the bolts off with a Dremel with a cutting wheel, the bolts for the sensor are M5 or M6 from memory, easy enough and cheap enough to replace with stainless steel bolts so the problem does not happen again.
I also re-calibrated the suspension heght after fitting the new sensor, and the car has been fine since
Post #649739 3rd Dec 2022 8:22am
