Home > Technical (L322) > Height Sensors help pleaee |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Yep, your model has a 6 pin connector!
24th Apr 2020 5:57pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
Thanks Joe, not sure why he has had this issue !! |
25th Apr 2020 9:51am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8222 |
IIRC that happened on mine, I got one from Ducky Dan and it only had three wires, the old one had six, I asked and he said the old one had been superseded. I fitted it and it worked fine..!! Can't see why it would need six wires when it is just a variable resistor like a petrol sender... surely only needs a couple of wires to work...!! Pete
26th Apr 2020 9:53am |
Pete, thanks, are you saying he can use the 3 pin one then? cheers |
26th Apr 2020 12:56pm |
Seems like things have moved on since I needed a height sensor.... .
26th Apr 2020 1:30pm |
I will have the conversation tomorrow with the indie and report back, all you can find online say fitment to 02-12 so we shall see |
26th Apr 2020 1:42pm |
See here on Island 4x4
26th Apr 2020 2:49pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 223 |
Mine through up suspension fault yesterday, fault code for left front so had both front wheels off today for a look see, unbolted from suspension arms and checked the readings on the foxwell while moving sensor arm up and down both doing more or less what I expected to see so back together been round the block and fault not come back just have to see how it goes and mine has three wires on left front and six wires on right front. |
26th Apr 2020 5:45pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
I attempted replacement of my right rear height sensor today but had to abandon the job after a couple of hours toil.
30th Nov 2022 9:03pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
Same happened to me when I did a front one. I had already unbolted the bracket from the car to change it. In the end I found some bolts in my tool box that threaded in to the new height sensor ok, so I literally just needed the bracket. Ended up cutting the plastic on the old sensor to get to the brass insert, which I could then grip to get the bolt out and the bracket off. I pulled the actual sensor off the insert before that…. 20 min job ended up being rather longer….
30th Nov 2022 9:12pm |
Jamesh7216 Member Since: 30 Dec 2021 Location: Baschurch Shropshire Posts: 37 |
I had the same problem on my car, I just cut the head of the bolts off with a Dremel with a cutting wheel, the bolts for the sensor are M5 or M6 from memory, easy enough and cheap enough to replace with stainless steel bolts so the problem does not happen again.
3rd Dec 2022 8:22am |
