Home > Technical (L322) > 2012 TDV8 FBH Not Working |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 208 |
Check your battery, if the voltage is too low the FBH won’t start. |
29th Nov 2022 8:59pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
If the remote won't pair, you may need to change the battery in it. Although my remote was working and lighting up, it would not pair with the car. Swapping the battery solved this issue. It seems the transmitter needs a full 3V.
30th Nov 2022 12:11am |
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 59 |
I thought the outside temperature had to be below 5 degrees for the FBH to work. 2007 3.6 TDV8
30th Nov 2022 12:44pm |
tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69 |
Thanks for the replies thus far - I'll check the battery voltage and report back.
30th Nov 2022 1:08pm |
