Home > Technical (L322) > Fan mounting bracket torque settings |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
When I did mine I think I used the torque setting of an equivalent sized bolt used elsewhere if that makes sense. |
28th Nov 2022 9:30pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 345 |
I looked up torque settings for m8 bolts got 48nm this bracket is under a lot of stress and forces due to it housing the fan 2012 Range Rover Westminster 4.4 TDV8
29th Nov 2022 7:22am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It's still an M8 fixing though, any more and you risk stretching the bolt or tearing threads out of the tapped hole. |
29th Nov 2022 7:29am |
That’s what I’ve set them at, stupid thing is I spent a hour going through the WM and although it’s mentioned I can’t see any reference to the torque 2012 Range Rover Westminster 4.4 TDV8
29th Nov 2022 7:36am |
I think that's what I set mine to and it hasn't fell off yet. |
29th Nov 2022 11:06am |
