Home > Technical (L322) > Intake manifold cleaning
Umiar
Poland 2011 Range Rover Vogue TDV8 Zambezi Silver
Removing whole manifold is an easy job. Few bolts an it’s out. Then use kerosine to clean the black sh** inside - works great and it’s cheap. Just be careful with the small bolts which holds the black pins from the engine plastic cover - I broke 3 of them
Post #648031 14th Nov 2022 8:06am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
What are you talking about?
Post #648052 14th Nov 2022 1:50pm
Umiar
Which part of my message is not clear for you?
I will try my best Wink
Post #648108 15th Nov 2022 6:29am
jaguar3
How to remove both manifolds still not clear. Its huve work, no?
Post #648109 15th Nov 2022 6:37am
GraemeS
The air intake AKA donut, not the inlet manifolds.
Post #648119 15th Nov 2022 8:42am
Umiar
Only donut one. Then you can reach by hand or some clever tools inside the rest of the manifold and clean it.
Prepare kerosine, solvent, brake cleaner and lots of old socks - they are the best for the job.
First kerosine with some tool for scratching (like the one you clean bottles). When it’s clean from black stuff, use something strong (microwave, ovencleaner), leave to dry.
There is a youtube video how to remove manifold step by step.
And after this process you can use liqui moly just to clean the end part of the manifold.
Be careful when removing throttle body and egr pipe, there are rubber seals inside.
Post #648209 16th Nov 2022 6:16am
jaguar3
Ou, donut is removed and cleaned already, its easy. I use high pressure washer for that. But Iam talking about manifolds, that is quite impossible on this engine at home.
Post #648210 16th Nov 2022 6:22am
Umiar
Well, not exactly.
You have to disconnect fuel lines and remove injectors - easy if they are not blocked.
But whole process is not worth it. You will remove most of black Censored by hand. And belive me, few months and it will grab it again.
The only way to get rid of it is blinding egr outlet and disable it in ecu software.
Post #648246 16th Nov 2022 2:56pm
