![]() | Home > Technical (L405) > Help Needed - Fuel problem |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
Fuel Injection pump? Whats the diesel pressure like at the injectors? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Try changing the fuel filter. Had a neighbour get a fuel rail pressure warning on his Peugeot after running it low on fuel and then topping the tank up …he had disturbed a load of grunge in bottom of tank that then clogged filter. A cheap and easy check. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Lee350 Member Since: 11 Nov 2022 Location: Great Yarmouth Posts: 3 ![]() ![]() |
Tried that and no different. Thanks |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
I can tell you the sorry story about my tractor.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Whilst not the same fault code but worth checking the connector to the HPFP pressure sensor as it is known to cause erroneous pressure readings.
fixed. Thanks for the help
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
There was a similar problem on a youtube post called `Saving salvage` they found it to be the second pump, a right |
