Home > Technical (L405) > Help Needed - Fuel problem |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
Fuel Injection pump? Whats the diesel pressure like at the injectors? |
11th Nov 2022 3:24pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Try changing the fuel filter. Had a neighbour get a fuel rail pressure warning on his Peugeot after running it low on fuel and then topping the tank up …he had disturbed a load of grunge in bottom of tank that then clogged filter. A cheap and easy check. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
12th Nov 2022 1:31pm |
Lee350 Member Since: 11 Nov 2022 Location: Great Yarmouth Posts: 3 |
Tried that and no different. Thanks |
12th Nov 2022 8:06pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1230 |
I can tell you the sorry story about my tractor.
13th Nov 2022 4:00pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Whilst not the same fault code but worth checking the connector to the HPFP pressure sensor as it is known to cause erroneous pressure readings.
13th Nov 2022 7:55pm |
fixed. Thanks for the help
18th Nov 2022 7:37am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
There was a similar problem on a youtube post called `Saving salvage` they found it to be the second pump, a right to get to. |
18th Nov 2022 8:24am |
