![]() | Home > Technical (L322) > Judder/shudder/pulsating |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
Prop shaft? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
If you get the 'clunk' when you take your foot off / on, the gas then it may be a problem with the drive train, prop shaft / drive shaft problem. Sounds like something is worn and backlash will give you that clunk.
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 ![]() ![]() |
Cheers for the replies lads, much appreciated. I will take it back to my mechanic to have another look. I'm sure its not the torque converter, it changes gear pretty well amd doesn't drop the revs when its locked up, there's no fluctuation either.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
If you have the car stationary does it do it if you rock the steering wheel side to side? [with the engine running]
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 57 ![]() ![]() ![]() |
Sticking brake calipers? |
No it doesn't do it while stationary, and I have checked calipers after a good spin and theyre not hot at all they are bearly warm even. I drive 100 miles a day in it.
I may well be wrong ( wouldn't be the first time |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Get the engine and gearbox mounts checked. |
