Home > Technical (L322) > Judder/shudder/pulsating |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Prop shaft? |
7th Nov 2022 10:11am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
If you get the 'clunk' when you take your foot off / on, the gas then it may be a problem with the drive train, prop shaft / drive shaft problem. Sounds like something is worn and backlash will give you that clunk.
7th Nov 2022 10:16am |
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 |
Cheers for the replies lads, much appreciated. I will take it back to my mechanic to have another look. I'm sure its not the torque converter, it changes gear pretty well amd doesn't drop the revs when its locked up, there's no fluctuation either.
7th Nov 2022 10:59am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
If you have the car stationary does it do it if you rock the steering wheel side to side? [with the engine running]
7th Nov 2022 12:31pm |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 51 |
Sticking brake calipers? |
9th Nov 2022 5:43pm |
No it doesn't do it while stationary, and I have checked calipers after a good spin and theyre not hot at all they are bearly warm even. I drive 100 miles a day in it.
10th Nov 2022 9:32am |
I may well be wrong ( wouldn't be the first time ) but, the 'wheel wobble' symptoms that you report would suggest that it is not a gearbox / TC problem, vibrations maybe, but not wobble. Try switching the front / rear wheels around and see if the problem remains. ( Simple cheap start to the diagnosis ) other than that, see if your mechanic can see anything when it is up on the ramp on Thursday - play in the driveshafts, U/J's???
10th Nov 2022 10:21am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Get the engine and gearbox mounts checked. |
10th Nov 2022 10:34am |
