Home > Technical (L322) > Front windows opened on their own and won't close! |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
If you have an IID tool, you could try running the window calibration routine. It may not be able to run the routine, but worth a shot. Kev
5th Nov 2022 12:24pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3076 |
I did wonder about looking to see if the IID will show if any of the switches are registering a button press. Will give a try too, thanks!
5th Nov 2022 12:30pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Battery voltage quite low, once charged I reckon the problem will have fixed itself, maybe |
5th Nov 2022 12:54pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Try the Global closing function and see if anything happens? |
5th Nov 2022 1:18pm |
Problem found and partially solved.
5th Nov 2022 1:19pm |
Solved!
5th Nov 2022 2:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
that switch module is so prone to water ingress....if you have the driver window open a few cm's and then use the wiper wash then it dowses the whole thing with spray.. ... - .- -.
5th Nov 2022 2:59pm |
Great news! Well done David! Kev
5th Nov 2022 3:41pm |
Thanks guys.
5th Nov 2022 4:49pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
That's why I fitted wind deflectors. Never trusted that switch cluster being water resistant in the slightest...Good that you managed to sort it, OP and thanks for sharing |
5th Nov 2022 9:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
That's a relief David...
6th Nov 2022 12:31am |
