Home > Technical (L322) > Front windows opened on their own and won't close!
dhallworth
Latest problem to grace the Supercharged has reared it's head today!
I've not used it since last Sunday, walked up to it this morning and unlocked it without any problems. The side steps folded out normally, and everything looked ok.
I climbed in, put the key in the ignition switch and turned the ignition on and at exactly the same time, at exactly the same speed both front windows opened. When you pull the switch to close them nothing happens.
If you pull the switch to the close position and hold it you can hear the regulators in the doors click but the windows don't make any attempt at all to close.
The car started and ran with no problems, battery voltage is 12.4v with it switched off and over 14v with the engine running.
At the moment the car is back inside with the battery disconnected as it's raining up here and the windows won't close Rolling Eyes
The workshop manual states:
Quote:
The front windows are controlled by their respective door modules integrated into the window switch packs.
Surely I won't have 2 door modules go down at once! Next plan is to disconnect the drivers door switch pack and see if I can get the passengers one too close. Other then that I'm kinda out of ideas.
Anybody got any ideas?
Thanks!
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #647411 5th Nov 2022 12:22pm
knwatkins
If you have an IID tool, you could try running the window calibration routine. It may not be able to run the routine, but worth a shot. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #647412 5th Nov 2022 12:24pm
dhallworth
I did wonder about looking to see if the IID will show if any of the switches are registering a button press. Will give a try too, thanks!
It's certainly odd as there's nothing in the car that feels damp and the windows haven't been steamed up at all. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #647413 5th Nov 2022 12:30pm
dingg1
Battery voltage quite low, once charged I reckon the problem will have fixed itself, maybe Cool
Post #647414 5th Nov 2022 12:54pm
kevinp
Try the Global closing function and see if anything happens?
Post #647417 5th Nov 2022 1:18pm
dhallworth
Problem found and partially solved.
I removed the drivers door card and unplugged the switch pack. Reconnecting the battery and putting the ignition back on then allowed me to shut the passengers side window.
I then stripped the switch pack for the drivers side and found this…
When I was unloading the TDV8 from the trailer last weekend it was torrential rain and it looks like there’s moisture got into the switch pack.
I’ve cleaned the whole thing with contact cleaner and a brush so with a bit of luck it might survive!
Post #647418 5th Nov 2022 1:19pm
dhallworth
Solved!
Cleaning that corrosion off the window switch pack has resumed normal service with everything working on it as it should.
Strange thing is it didn’t appear to get *that* wet the night it happened but there must’ve been enough moisture that got in to cause problems.
Post #647421 5th Nov 2022 2:15pm
that switch module is so prone to water ingress....if you have the driver window open a few cm's and then use the wiper wash then it dowses the whole thing with spray.. ... - .- -.
Post #647423 5th Nov 2022 2:59pm
knwatkins
Great news! Well done David! Kev
Post #647428 5th Nov 2022 3:41pm
dhallworth
Thanks guys.
Just pleased it was an easy fix! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #647433 5th Nov 2022 4:49pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
That's why I fitted wind deflectors. Never trusted that switch cluster being water resistant in the slightest...Good that you managed to sort it, OP and thanks for sharing Thumbs Up
Post #647450 5th Nov 2022 9:17pm
That's a relief David... Confused
Just in case others read this thread down the line? There are several different switch packs through the years and fitting the wrong-aged switch pack will affect mirror functioning amongst other oddities... Thumbs Up
Post #647458 6th Nov 2022 12:31am
