Home > Technical (L322) > Loud knocking on startup
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
My 2012 does this in the morning ive changed all tensioners etc on front of engine just done an oil change for smith and allen oil and its still there anyone got any ideas, after a min or so the noise is gone 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #647328 4th Nov 2022 5:05pm
Merchy
I am not an expert, but if the noise is not coming from the pulleys / tensioners / belts area, try listening with a long steel rod placed on various parts of the engine and your ear ( Obviously not too near moving parts !! )
It also sounds like it could possibly be from the injectors / tappets.
It may sound daft to those who have never used these - but a listening stick placed against parts of the car and the other end placed against the casing of ear defenders is a superb way of determining where a noise is coming from. We do this at sea all the time with high accuracy. Using ear defenders cuts out all the background noise and acts as an amplifier. The listening stick can be placed into very hard to reach areas.
Good luck Thumbs Up
Post #647337 4th Nov 2022 6:03pm
kevinp
Could be the fan. Can you rock the blades? Engine stopped obviously.
Post #647339 4th Nov 2022 6:07pm
Furnitureman
Going to get a stethoscope and I was thinking about the fan being an issue as it doesn’t do the loud jet sound on start up anymore and it’s much worse now it’s colder 2012 Range Rover Westminster 4.4 TDV8
Post #647350 4th Nov 2022 7:23pm
Furnitureman
Post #647352 4th Nov 2022 7:39pm
GraemeS
A big screwdriver works very well as the tip can be moved small distances to find the exact spot and the end of the handle doesn't poke holes in one's ear.
Post #647387 5th Nov 2022 7:19am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Agreed, don’t waste money on a stethoscope, a large / long screwdriver is just, if not more effective + can be used for its intended purpose also Thumbs Up
Post #647389 5th Nov 2022 7:50am
dhallworth
That does sound plasticky. I agree with the above about checking the fan for play or obstructions.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #647402 5th Nov 2022 11:00am
