Home > Technical (L322) > Loud knocking on startup |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
I am not an expert, but if the noise is not coming from the pulleys / tensioners / belts area, try listening with a long steel rod placed on various parts of the engine and your ear ( Obviously not too near moving parts !! )
4th Nov 2022 6:03pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Could be the fan. Can you rock the blades? Engine stopped obviously. |
4th Nov 2022 6:07pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 346 |
Going to get a stethoscope and I was thinking about the fan being an issue as it doesn’t do the loud jet sound on start up anymore and it’s much worse now it’s colder 2012 Range Rover Westminster 4.4 TDV8
4th Nov 2022 7:23pm |
4th Nov 2022 7:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
A big screwdriver works very well as the tip can be moved small distances to find the exact spot and the end of the handle doesn't poke holes in one's ear. |
5th Nov 2022 7:19am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 863 |
Agreed, don’t waste money on a stethoscope, a large / long screwdriver is just, if not more effective + can be used for its intended purpose also |
5th Nov 2022 7:50am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3072 |
That does sound plasticky. I agree with the above about checking the fan for play or obstructions.
5th Nov 2022 11:00am |
