Home > Technical (L322) > tow bar wiring |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
I think I know what you are getting at, the wire coming from the plug in the spare wheel does not match the colour code for the towing plug 13-pin socket, the JLR socket is sealed against water ingress which makes it difficult to track where they go, I did pull it apart about 3 years ago but made no notes. |
4th Nov 2022 11:54am |
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 |
I can confirm the 2010 onwards plug in the wheel well is plug and play with the tow bar wiring, although I believe this only to be for a 7pin connection. Not a problem for me as I only tow a trailer, rather than a caravan for example. |
4th Nov 2022 1:57pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Here you go.......
4th Nov 2022 5:06pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
(In reference to 2010-2012 cars) The car can be programmed for a 13 pin loom or 7 pin. By default, it is set up as 7 pin. It can be changed to 13 pin in the CCF files. I have 13 pin electrics fitted and 13 pin programmed to the CCF. I guess balloonengineer has an old loom they're trying to retrofit to the newer model? 2015 Range Rover Autobiography 4.4 SDV8 |
4th Nov 2022 10:17pm |
Mine had the two 7 pin sockets, I changed it to 13 pin and wrote the table above. BMW i3 Electric Car
4th Nov 2022 10:29pm |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 |
Thanks for the replies, and especially the table, very useful
4th Nov 2022 11:45pm |
