Home > Technical (L322) > tow bar wiring
Balloonengineer
tow bar wiring
Can anyone confirm if I am correct?
Pre-2010 vehicles the tow bar wiring plugs into the white control box in the rear RH compartment
Post 2010 vehicles just plug into the wiring loom in the spare wheel well.
If so, does anybody have a copy of the wiring/loom diagram for a 2010/12 vehicle
(or wiring installation diagram from a previous fit)
Yes, I have checked out the PF jones website, and that is how it appears to me. I am sure I have seen a diagram somewhere but can't find it.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #647282 4th Nov 2022 11:44am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I think I know what you are getting at, the wire coming from the plug in the spare wheel does not match the colour code for the towing plug 13-pin socket, the JLR socket is sealed against water ingress which makes it difficult to track where they go, I did pull it apart about 3 years ago but made no notes.
Post #647287 4th Nov 2022 11:54am
Westminster_Bri
I can confirm the 2010 onwards plug in the wheel well is plug and play with the tow bar wiring, although I believe this only to be for a 7pin connection. Not a problem for me as I only tow a trailer, rather than a caravan for example.
Post #647306 4th Nov 2022 1:57pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Here you go.......
 BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #647329 4th Nov 2022 5:06pm
garyRR
(In reference to 2010-2012 cars)
The car can be programmed for a 13 pin loom or 7 pin. By default, it is set up as 7 pin.
It can be changed to 13 pin in the CCF files. I have 13 pin electrics fitted and 13 pin programmed to the CCF.
I guess balloonengineer has an old loom they're trying to retrofit to the newer model? 2015 Range Rover Autobiography 4.4 SDV8
Post #647377 4th Nov 2022 10:17pm
AJGalaxy2012
Mine had the two 7 pin sockets, I changed it to 13 pin and wrote the table above. BMW i3 Electric Car
Post #647379 4th Nov 2022 10:29pm
Balloonengineer
Thanks for the replies, and especially the table, very useful
Best wishes
Post #647383 4th Nov 2022 11:45pm
