![]() | Home > Technical (L322) > Front lower arm bolt… |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1224 ![]() ![]() ![]() |
If the bush is still in good condition, then it could be that the nut is tightening up as there is not enough thread, plus it could be a manufacturing defect with too short a thread ( not unknown )
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 440 ![]() ![]() ![]() |
Thanks for the advice. Will have a look for the wiki section, is that a search thing or a specific section of the site? (I’m quite new as you can tell!) |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
The Wiki is top right, under the fullfatrr banner…
Brilliant thanks.
Not too expensive = inaccurate = might as well not bother.
Noted.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3155 ![]() ![]() ![]() |
The different part numbers are due to difference chassis numbers according to the LR online catalogue.
Thanks. I guess they do the same thing so will go for the one with the longer thread.
This is the Norbar one - it's got a NSN which is always a good sign...
Thanks. Found it for a £100. Will get it.
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
Halfords advanced version has a lifetime warranty. Also own a 1976 Land Rover 101 3.5 V8.
