Home > Maintenance & Mods (L405) > Jacking confusion
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Jacking confusion
I’m looking in the manual for information on jacking the car up. I’ve got deployable side steps (well, the passenger one deploys, the drivers side is stuck in the out position!).
The manual is confusing. It says warning
“The deployable side steps must be in the stored position and the system switched off, when raising the vehicle. Do not raise the vehicle with the deployable side steps in the deployed position.”
But then it says in notes
“If the vehicle is fitted with deployable side steps, the side steps must be in deployed position to allow access to the jacking points.”
Which is it? Deployed or not?
Thanks 2017 (67) Vogue SE Corinthian Grey
Post #647270 4th Nov 2022 10:15am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
From what I have seen the jacking point is part of the deployable steps which would point to the steps being stowed, not deployed if that makes sense.
Post #647275 4th Nov 2022 11:18am
knwatkins
Steps stowed Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #647281 4th Nov 2022 11:43am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Agree, steps stowed and switched off, using the step bracket to jack up.
Post #647283 4th Nov 2022 11:45am
Abacus405
Thanks for the replies.
As my drivers step is stuck in the deployed position, it means I can’t Jack that side of the car 😭
I’ll have to sort the step problem first then. 2017 (67) Vogue SE Corinthian Grey
Post #647289 4th Nov 2022 12:01pm
Tinman
You can remove the step by undoing 4 hex bolts and then jack the front up on the bracket which is not motorised.
Post #647290 4th Nov 2022 12:22pm
Tinman
Or you could put the car into extended mode leave the door open then work on the step.
Post #647292 4th Nov 2022 12:23pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
My driver’s side step was also stuck recently. I managed to sort it with silicon spray at all the joints and giving the step a helpful push with my foot at the time it was trying to close. Hope this may help. 2016 SDV8 AB
Post #647315 4th Nov 2022 3:33pm
Abacus405
I’ll give that a try when it stops raining, thanks 2017 (67) Vogue SE Corinthian Grey
Post #647317 4th Nov 2022 3:40pm
Abacus405
For anyone interested, after lubricating all the bits and bobs I could see, the step now retracts. Little wins! 2017 (67) Vogue SE Corinthian Grey
Post #647599 7th Nov 2022 3:29pm
ABAB
Brilliant - this was a satisfying fix! 2016 SDV8 AB
Post #647616 7th Nov 2022 6:41pm
caymanblack
Just to be clear when jacking the car up the steps must be under the car? Then the jack placed on the steps brackets? How do you switch the step off so they dont work? Bow down overfinch modified
Post #651283 20th Dec 2022 6:39pm
knwatkins
You don't need to disable them manually. They automatically sense off road or jacking situations and disable themselves. Kev
Post #651284 20th Dec 2022 6:43pm
caymanblack
Great thx Kev , they have to be stowed away right? Thumbs Up overfinch modified
Post #651286 20th Dec 2022 6:49pm
knwatkins
Yep Thumbs Up Kev
Post #651289 20th Dec 2022 7:13pm
