Home > Technical (L322) > Does this sound like the alternator to you?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I have an engine speed related whine-most noticeable on tickover and when revving while stationary, but less so while driving (drowned out by the other normal noises).
IID tool shows between 13.2 and 15 volts while driving, mostly at 14.7. No other symptoms.
Looks like the original is still on the car.
I assume a Denso is the only one to get?
Thanks all.
Post #647129 2nd Nov 2022 12:05pm
I would think it's more likely to be one of the belt runners or tensioner, take the belt off and spin them, if they feel/sound rough you know that's the one... Thumbs Up
You can briefly run the engine and if it still makes the noise you have ruled out a lot of things..!! Pete
Post #647147 2nd Nov 2022 6:08pm
philip1972
Good idea Thumbs Up
Post #647150 2nd Nov 2022 6:32pm
If it's a grubling bearing then it probably wouldn't show on IID sir... As Above, remove the aux belt and run it briefly... Thumbs Up
Post #647211 3rd Nov 2022 3:49pm
philip1972
Thanks. Not a grumbling sound, just a whine that’s quite high pitched.
Post #647214 3rd Nov 2022 3:56pm
philip1972
Just to update, I changed the alternator today and the whine is gone.
Normal, quiet service is resumed.
Post #650418 10th Dec 2022 8:35pm
