Home > Maintenance & Mods (L322) > Brake calipers improvement
Page 2 of 3 <123>
pcourtney
are these the right ones ?
https://www.pro-bolt.com/stainless-steel-b...sbn10-4z1/
£20 quid for a pack of four including vat
Stainless Steel Bleed Nipple M10 Front Brake Caliper Pack x4 (SSBN10-4Z1)
Material: Stainless Steel
Product Type: Brake / Caliper
Thread Diameter: 10mm
Thread Pitch: 1.00mm
Length: 29mm
Socket Size: 11mm
Post #646366 24th Oct 2022 1:03pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
If the nipple has corroded inside that would suggest the brake fluid maintenance has been overlooked a few times. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #646378 24th Oct 2022 2:30pm
JayGee
Steel/Alloy thread interfaces will cause galvanic corrosion. Stainless steel won't be any better. 2012 TDV8 Vogue (L322)
Post #646380 24th Oct 2022 2:45pm
pcourtney
maybe, but let me get the frigging M10 bolts out first Big Cry
when I do get them out I will be looking out for some rubber covers to give them a little more protection when I put new ones in
Post #646386 24th Oct 2022 3:19pm
pcourtney
and I guess Titanium is no better ??
I will need to buy 4 x new nipple bolts anyway, so are you saying that there is no material that will help slow down the corrosion, if so this is really awful design on the part of JLR and Brembo Evil or Very Mad
Post #646387 24th Oct 2022 3:22pm
Gremlin500
True, in the prescence of water but there shouldn’t be any water in your brake fluid, if changed regularly.
There’s no option of alloy nipples of course, they’d just snap like carrots Rolling with laughter
I sparingly use copper grease on mine, knowing that the thread is outboard of the nipple seat, so fluid and grease should never mingle other than when bleeding, when the flow is away from the calipers anyway. Thumbs Up
EDIT: Sorry it wasn’t copper grease, I used PTFE tape! (on new nipples/new brakes).
I don’t think its a big deal, if used sparingly, anything that provides a barrier will prevent corrosion, the threads
are outboard of the brake fluid, so contamination of fluid is highly unlikely in operation, only when bleeding when the
old fluid is flushing any particles out of the caliper. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #646388 24th Oct 2022 3:24pm
JayGee
Covers won't make any difference - it's the steel of the nipples interfacing with the alloy of the callipers that causes the problem. Maybe look for some lightweight 'racing' nipples. Some alloys of Aluminium are very strong and are used in aerospace applications so well up to the job. Red Rubber grease is safe to use on the threads as it's designed to contact brake fluid. 2012 TDV8 Vogue (L322)
Post #646389 24th Oct 2022 3:25pm
pcourtney
these Titanium ones sound the answer - anyone used them - here is the sales blurb
Unrivalled anti-corrosion resistance. Titanium takes over 10 years to tarnish the surface and over 40 years to show microscopic signs of corrosion.
Twice as strong as stainless steel. We only use grade 5 6Al-4V titanium in our bleed nipples. With its high titanium content along with small amounts of aluminium and vanadium grade 5 6Al-4V titanium merges its superior anti-corrosion properties with high tensile strength giving you the strongest and most durable bleed nipples on the market.
Lightweight. Almost half the weight of stainless steel and twice as strong.
No more snapped bleed nipples. Saving yourself £100s in the future. Steel bleed nipples will always rust and seize. Its only a matter of time. Once seized they are prone to snapping when the brakes are bled.
Best case scenario, the snapped bleed nipple can be extracted
Worst case scenario, a new caliper is needed costing many hundreds
Our titanium 6Al-4V bleed nipples will never rust or seize
Post #646390 24th Oct 2022 3:28pm
D3Jon
Agree - first thing I thought of when I saw this thread. Stainless steel bleed nipples in a steel caliper [EDIT - or alloy in the case of the fronts] will induce bi-metallic corrosion.
In reality, this shouldn't be a massive issue, so long as they're used (i.e. opened) occasionally. But if left for a couple of years, there could a hell of a fight trying to shift them.
If you do go ahead and use them, then as suggested by others, I'd cover the threads with a light coat of ceramic brake grease or similar to act as a buffer between the two dissimilar metals.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #647069 1st Nov 2022 2:54pm
D3 Jon, it's worse than that, it's steel, stainless or otherwise into alloy..!!
You shouldn't use copper grease on alloy callipers, it's just adding another metal into the mix and will promote corrosion...
Don't know if this is compatible with brake fluid but seeing as fluid only tends to flow out of a bleed nipple I'd use some of this... Used it on the boat and it is good... Thumbs Up
https://www.force4.co.uk/item/Harken/Tef-G...-Paste/CM8 Pete
Post #647071 1st Nov 2022 3:17pm
D3Jon
Thanks, good point and just realised that myself Pete. Thumbs Up
Was thinking it was the (steel) rears in question as that's what I've just been working on on my 4.4 TDV8 - but yes, of course, the front's have steel nipples (an alloy in itself) in a more alloy, er.. alloy if that makes sense - arghhh! Very Happy Very Happy
2014 Disco 4 HSE
Post #647106 1st Nov 2022 9:40pm
Gremlin500
See my update above….. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #647109 1st Nov 2022 10:52pm
D3Jon
Not a bad shout - a thin layer of PTFE tape sounds like it should do the job (So long as it doesn't get near the sealing face of the bleed nipple)!
Might also help with vacuum bleeding - one thing I always have issues with with a vacuum bleeder is outside air sucking past the threads of the opened bleed nipple.
2014 Disco 4 HSE
Post #647134 2nd Nov 2022 12:18pm
Gremlin500
@D3Jon:
Yeah, there is a lot of BS on the internet about brake fliud “dissolving PTFE tape” from armchair “experts” however despite looking up each ingredient of DOT4 and searching “compatibility with PTFE” one by one, I was unable to find any support for this theory, or any scholarly articles in support thereof, so until anyone tells me otherwise with supporting references, I’ll continue to do so, but all please make your own minds up, thanks. Important to say, the PTFE is there only on the threads and not there to seal, just to be an electrical insulator to any possible galvanic action as a barrier between the dissimilar metals.. One of the best well-documented properties of PTFE is that is an excellent electrical insulator.
As for “stainless” steel? Read this:-
https:/www.boatus.com/expert-advice/expert-advice-archive/2016/august//not-so-stainless-steel
Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #647139 2nd Nov 2022 2:28pm
JayGee
Goodridge stainless steel braided flexible brake hoses have PTFE liners. 2012 TDV8 Vogue (L322)
Post #647140 2nd Nov 2022 2:36pm
Page 2 of 3 <123>
