![]() | Home > Maintenance & Mods (L322) > Brake calipers improvement |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
A couple weeks ago I was changing brake fluid an notice that bleed valves are heavily rusted, so I ordered some stainless steel ones from this place in UK:
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Nice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35481 ![]() ![]() |
nice looking nipples |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Can you confirm the type you ordered please? M7? |
CTC - M10 (1 mm),
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Nino,
Mike, small visual difference (Brembo-TRW) but same size thread and length. PRO BOLT fit fine. in the picture left one is TRW
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Nino,
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
Don't use grease on bleed screw threads unless you're very confident it's brake fluid compatible (most greases won't be).
Seems like red rubber grease is the stuff for the job. Not sure of its longevity but I’ve bought a bunch of rubber dust covers and by mounting the retaining loop on the thread-side of the screw should provide a great seal to keep the road grime out and grease in! 🤞
beemer5711 Member Since: 31 Jul 2022 Location: Wales Posts: 72 ![]() ![]() |
Have never thought about replacing for stainless before, great idea! |
