Home > Technical (L405) > SDV8 engine failure
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Vogue wrote:
That looks like it’s done 150k miles without an oil change. We have tractors, 360 excavators and plant with the equivalent hours of 250k / 300k miles and they still look like new under the rocker covers with absolutely no build up like that. I genuinely would suspect no oil changes looking at that.
Totally agree, I’ve not seen one that dirty insides especially with that mileage for many years, and I see quite a lot.
The only other thing would be thousands of short journeys with the engine never actually warming up??
Post #621738 29th Jan 2022 10:20am
Baltic Blue
Dave, that would be my BT Land Rover then Rolling with laughter
Post #621739 29th Jan 2022 10:24am
diesel Dave
Rolling with laughter Rolling with laughter Rolling with laughter Yeah and I suspect many others too Mike.
Post #621740 29th Jan 2022 10:25am
Mr John Paul Billson
You say all of the services were done by Land Rover. Are you sure, I had the same problem but it was found that the cause was the oil filter of a well-known brand? it would only take the last oil change to have caused this problem. reducing the oil flow causes overheating of the bearing and results in excessive soot and sludge being created causing the oil filter life to be reduced and compounding the problem. Mine did this after only 1200 miles from having an oil and filter change with what was supposed to be a quality oil and filter. Message me if you need more details. Thanks, Paul
Post #647049 1st Nov 2022 10:49am
