![]() | Home > Technical (L405) > SDV8 engine failure |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Who's rebuilding it? QP? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
That hasn't just been caused by EGR. I suspect that the sump breather or oil separator has been blocked.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
as above, unsure how oil contamination can happen from the EGR
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1311 ![]() ![]() |
Wow you must be gutted.
my mind went to rings too . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
I wonder how it compares to the several engines that have had the sump removed to change the oil level sensor ??
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
I've only ever once seen that kind of mess inside an engine. It was a small BMW diesel with a full BMW history for most of its life. The problem was only spotted to a brake failure problem (vacuum pump failed due to crap in the oil).
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 298 ![]() ![]() ![]() |
If the BMW had a full BMW history, then surely BMW were at fault for supplying the cheap oil? 2013 Vogue SE SDV8
Problem was that the BMW history was only for most of it's life, the last 2 services had been done by small garages and the car had been run to nearly 15K miles between the services which apparently was long enough for the alleged cheap oil to break down.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Blimey, that engine looks like its been on a diet of fried breakfast and egg, ham and chip dinners |
Hutch526 Member Since: 06 Nov 2021 Location: Uk Posts: 6 ![]() ![]() ![]() |
Thank you for the feedback guys.
The oil trap for the engine breather is mounted to the underside of the EGR cooler with the breather pipe appearing to be push fit through a rubber seal into the top of the oil trap. If the breather pipe, which feeds into the primary turbo inlet, became blocked then I would expect a big mess in the vicinity of the EGR cooler. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3783 ![]() ![]() |
That looks like itโs done 150k miles without an oil change. We have tractors, 360 excavators and plant with the equivalent hours of 250k / 300k miles and they still look like new under the rocker covers with absolutely no build up like that. I genuinely would suspect no oil changes looking at that. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Wonder if its a victim of full MD history service lottery scheme? |
