Home > Maintenance & Mods (L322) > ZF8HP slipping issues |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
My 4.4 tdv8 L322 has a loose gearbox in the lower gears.
31st Oct 2022 8:30pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2491 |
How does it behave in manual mode? Has it always behaved like this?
1st Nov 2022 7:17am |
Based on my internet reading, this was what I was expecting to need to do next. I want to be sure the TC isn’t faulty before I started anything as that’s something I’d get a specialist to do… Although, I’m still deciding if even the seals and solenoids is a job I want to tackle on my gravel sloping driveway… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
1st Nov 2022 7:51am |
I rarely use manual or sport mode, and only when already at speed. However, I have tested manual and the behaviour is the same. It seems to be a problem engaging the gear rather when or which gear. The behaviour hasn’t always been like this and it’s been getting worse. The gearbox oil change was supposed to help this, which is when we found the faulty cooler solenoid - hence the fear of a cooked gearbox. I’d did help for a bit, but assume the gearbox has adapted to the change. Oh, and the correct ZF oil was used (apparently)
Very similar indeed! Except the quick (attempted) change to 2nd. Mine seems all revs until the speed matches the higher revs and then changes. Although it could be that I simply cannot tell the 1st/2nd gear change attempt. Fettling the throttle does help and I do that also… but that frustrates me. The car should adapt to me, not the other way around
My googling has led me down that rabbit hole. Lots of options for BMWs but fewer with RR and many saying it’s not possible. TBH, I’d prefer to avoid this route as I’d be happy with the gearbox behaving normally. IMO with a major power increase then maybe… but not to fix unusual behaviour. [/quote] Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
1st Nov 2022 8:04am |
I think my next step is to grab a bottle of ZF fluid and ensure the fluid level is correct.
1st Nov 2022 8:06am |
You might want to try manual shifting to 1st before taking-off, then using around 1/3 throttle upshift at around 1700 rpm in gears 1 to 3 to get a feel for whether the TC and gear changing is working properly.
1st Nov 2022 8:36am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1477 |
It's rare for a ZF transmission to experience a mechanical fault.
1st Nov 2022 9:03am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Worth getting it looked at by a ZF transmission specialist to get a proper diagnosis before speculating what could be wrong and throwing parts at it. 2012 TDV8 Vogue (L322) |
1st Nov 2022 9:15am |
What am I looking for when doing this? I expect it to continue to rev as it does now… but will check when she’s back on the road. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
1st Nov 2022 9:39am |
Agreed. I’d like to be forearmed before starting this conversation off… however if the responses are “ah it’s THIS. Replace it and all will be fine” then I’m happy to consider doing it. There will be a phone call with a specialist, even if to get all the information I can. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
1st Nov 2022 9:42am |
Cheers GaryRR. Do you (or anyone) know what the cost is to get this done? both with a specialist or on the driveway? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
1st Nov 2022 9:44am |
ZF8HP gearbox issues on these cars are very rare. A normal service just involves dropping the oil and replacing the pan / filter and does not include changing internal sleeves. 2012 TDV8 Vogue (L322) |
1st Nov 2022 10:25am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 741 |
I'd be tempted to go with your idea of checking the level before looking for other problems. It is VERY easy to get the level wrong - I changed my oil, thinking that the car was level, oil temp was correct and I had cycled the gears.
1st Nov 2022 10:44am |
You would be looking for positive gear changes without TC slip, just like a manual except that the clutch is automatic. With the right amount of throttle, by around 1700 rpm the torque should have tapered off enough to allow the gearbox to not decide to slip the TC on take-up of the clutches for the next gear. The change to 3rd will see the revs come back a long way as the gap to 3rd from 2nd is too great on this early version of the 8-speed, so don't apply too much throttle until the TC is locked unless you've taken the revs higher. This exercise requires that the take-off starts in command/manual mode 1st gear, either drive or sport mode. I always use this method when towing my 2.5T van when taking-off to keep the TC locked. |
1st Nov 2022 11:08am |
