![]() | Home > Maintenance & Mods (L322) > ZF8HP slipping issues |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
This has been done at Dartford Auto Transmissions, which is where they found the problem coolant solenoid had seized. So, pan & filter, oil, and pipes and cooler all changed. Apparently with ZF oil. As the problem is still there, more work is needed to resolve this, over and above a normal service. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Wow, an extra litre! thats a significant amount… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
I’ll give that a go… I just need to replace my front struts first (leaky airbag) and then can try it out. ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
So struts changed, and while out making sure all was well, I tried your suggestion GraemeS.
Oh, and I’ve been quoted £2,200 for a gearbox “rebuild” |
Thank you for the advice so far GraemeS. With you advice on checking in manual mode, I’ve found a sweet spot with the accelerator, easing off for it to fully engage the gear before reapplying power.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 ![]() ![]() ![]() |
Hopefully you find the sweet spot often enough and can just ignore it when it isn't behaving to your liking. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 ![]() ![]() ![]() |
Ffrr, did you get a resolution to this problem. Mine is doing similar things. Thanks Kev. |
Hi Kevin,
Oh, and good luck with yours!
Bare with me on this one, but try disconnecting your battery for about an hour and let me know if you think things have improved. |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
I have the same issue, specifically second gear (worst when cold but still does it when warmed up) it slips and doesn't want to go into third easily and the revs fluctuate..seems fine once it's in third. Appears to be getting worse. A filter/fluid change did nothing.
Sorry, been off the forum for a while due to a change of job...
