Home > Technical (L322) > Hitachi compressor exhaust valve silencer missing
Lummox
New Zealand 2006 Range Rover Supercharged 4.2 SC V8 Java Black
L322 4.2 S/C MY2006 102,000km.
Out of curiosity I had a look at the compressor in the spare wheel well and discovered that the sintered brass silencer was missing from the exhaust valve. I have read through a few threads here that explain how they become clogged and can cause problems with lowering the vehicle, and see that they can be replaced cheaply, or cleaned, or modified by drilling a hole.
My suspension seems to be running perfectly OK. The compressor looks shiny and brand new (though the air lines show manufacture dates of 2006). So I guess the cover keeps it well protected and clean.
Is it something I should replace? Does its absence create any problems? Should the dessicant in the drying chamber be replaced? (I read that the dessicant breaks down to dust and that can block the silencer).
Or is it something that I just ignore?
Post #646921 30th Oct 2022 10:53pm
dingg1
If people drill a hole in it to help vent pressure they may as well just remove it as Censored all gets filtered if its got a gaping hole in the filter. Whistle
Post #646925 31st Oct 2022 8:28am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Always made me wonder, why you wanted a filter on the exhaust? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #646931 31st Oct 2022 9:35am
I think it's just there to break up and silence the escaping air, it's quieter to have the air broken up by the sintered brass than just an open pipe, drilling a hole just helps it to exhaust quicker and still keeps some form of silencer...... Thumbs Up
I'd replace it but that's just me.... Pete
Post #646932 31st Oct 2022 9:47am
dingg1
I think its also the inlet as well as the exhaust, might be wrong though Question
Post #646940 31st Oct 2022 11:25am
Years since I looked at one, ignore my post then... does seem a bit pointless drilling a hole in a filter though...!! Pete
Post #646950 31st Oct 2022 12:54pm
mjdronfield
I agree Pete… and I’m one of those that drilled a hole in theirs. The car was stuck up in extended mode and only supposed to go 30mph. Garage quoted £700 to fit a new compressor. Think you can get the silencer bit for less than £40. The only time you can really hear the compressor running is if the seats are folded and the carpets up.
I did try cleaning the old silencer in brake cleaner, but it had no effect….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #646952 31st Oct 2022 1:13pm
mjdronfield
https://www.ebay.co.uk/itm/144480676130?ha...R_Lvt-OFYQ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #646953 31st Oct 2022 1:25pm
AJGalaxy2012
I fitted a FESTO silencer on mine, worked perfectly OK, £3.50 BMW i3 Electric Car
Post #646995 31st Oct 2022 6:26pm
Lummox
It looks like you can get the silencers pretty cheaply from Ali Express - if you know what thread size to order :
https://www.aliexpress.com/item/4000112203...XtCYUqdDJf
And if you want to do seal and dessicant upgrade, these people seem to know what they are talking about. Scroll past the product info for more details about diagnostic codes and likely causes.
https://4x4airseals.com/product/hitachi-ai...repair-kit
Since no one has mentioned any downside to the silencer being missing I think I will just leave mine alone. I dont have a back box on the exhaust, and I have a platform built in the back for the dog, so I can hardly hear the compressor or the exhaust valve.
Cheers.
Post #647028 1st Nov 2022 1:46am
