Home > Maintenance & Mods (L405) > Boot Mat
Boot Mat
Anyone bought one of these....??
https://www.island-4x4.co.uk/loadspace-bri...34907.html
Are they any good...?
Any other options...? Pete
Post #646746 28th Oct 2022 10:46pm
Phoenix
I've seen a couple in use, they appear to be overpriced by about £40....
Probably not what you're after, I use one of these www.amazon.co.uk/gp/product/B01IBGGD64
Here's the L405 version www.amazon.co.uk/UK-Custom-Covers-BL172-Tailored/dp/B01D1M7GE6
Post #646747 28th Oct 2022 10:56pm
I don't put animals or dirty things in the back so just want a mat, just in case....... I take it those rubber ones are a bit of a waste of money then..?? Pete
Post #646764 29th Oct 2022 9:37am
Phoenix
Well, the Britpart ones look overpriced, they're quite flimsy and seem to be a particularly poor grade of flexible-non-specific-rubber-substitute. Not at all heavy & dense like you'd expect a boot mat to be. A piece of 6mm Neoprene sheet you could cut to size would cost less.
Post #646766 29th Oct 2022 9:53am
CS
Mine has the 'Loadspace semi-rigid liner' VPLGS0263 which has worked well, but is probably overkill for your stated objectives. The cheapest emergency use solution might be to buy a small tarpaulin that could be put over the loadspace floor if and when required. Only Range Rovers since 1988
Post #646774 29th Oct 2022 11:21am
Gremlin500
I got one of these from http://www.prestigecarmatcompany.co.uk/
Heavy black rubber with checkerplate pattern, grippy surface, perfect fit, I’m very pleased with it.
It’s completely flat, no raised edges, doesn’t scuff easily like some do, only £47.95 at the time. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #646777 29th Oct 2022 11:56am
fisha
In the Evoque I had a cheap flexible plastic mat. Wasn’t soft rubber like a car mat , but was thin and could bend over on itself, and was easily wiped down.. The best bit about it was it had a lip round the edges. Only about an inch and a half but enough to catch spills or water off wet shoes etc. took a fair bit of beating from having things in the boot but never punctured. I’ve yet to find it for the l405 but am looking from time to time. V8 or else ...
Post #646784 29th Oct 2022 1:24pm
Gremlin500
I use a heavy rubber mat in the back of my pickup, and its surprising how much quieter it makes road noise from the rear, so must do similar in the fullfat, compared to plastic. Obvs less noticable to my ageing ears, lol! Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #646792 29th Oct 2022 3:45pm
Stuart-
I saw a genuine one in an L405 today so LR do make them. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #646799 29th Oct 2022 5:37pm
mjdronfield
I’d get a second hand genuine one if it were me mate.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #646804 29th Oct 2022 6:46pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I’ve got a non gen lying in the garage Pete, perfect fit , not a flat one so can take spillages. But I’m mibbe a wee bit far away to pop round for a brew though Whistle Mr. Green
Post #646861 30th Oct 2022 12:40pm
Chalky
If you want to keep the boot clean, this is by far the best on the market.... Thumbs Up Thumbs Up Thumbs Up
https://www.hatchbag.co.uk/land-rover-rang...t-phev-lwb All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #646869 30th Oct 2022 1:55pm
Cheers guys and thanks for the offer Mr Tee, it is a bit far..!
I've got the full boot bag thingy but I don't want to keep it, just want a mat to keep the carpet clean in case I do have to put something dirty in there, it will be once in a blue moon though...
I'll get a genuine one, just wondered if there was a better alternative, Craig found a better alternative for the footwell mats so I thought I'd ask... Thumbs Up Thumbs Up Pete
Post #646875 30th Oct 2022 2:34pm
