![]() | Home > Maintenance & Mods (L405) > Boot Mat |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
Anyone bought one of these....??
I've seen a couple in use, they appear to be overpriced by about £40....
I don't put animals or dirty things in the back so just want a mat, just in case....... I take it those rubber ones are a bit of a waste of money then..?? Pete
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
Mine has the 'Loadspace semi-rigid liner' VPLGS0263 which has worked well, but is probably overkill for your stated objectives. The cheapest emergency use solution might be to buy a small tarpaulin that could be put over the loadspace floor if and when required. Only Range Rovers since 1988 |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1590 ![]() ![]() ![]() |
I got one of these from http://www.prestigecarmatcompany.co.uk/
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
In the Evoque I had a cheap flexible plastic mat. Wasn’t soft rubber like a car mat , but was thin and could bend over on itself, and was easily wiped down.. The best bit about it was it had a lip round the edges. Only about an inch and a half but enough to catch spills or water off wet shoes etc. took a fair bit of beating from having things in the boot but never punctured. I’ve yet to find it for the l405 but am looking from time to time. V8 or else ... |
I use a heavy rubber mat in the back of my pickup, and its surprising how much quieter it makes road noise from the rear, so must do similar in the fullfat, compared to plastic. Obvs less noticable to my ageing ears, lol! |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 337 ![]() ![]() ![]() |
I saw a genuine one in an L405 today so LR do make them. 2017 4.4 SDV8 Autobiography in black
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I’d get a second hand genuine one if it were me mate.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
I’ve got a non gen lying in the garage Pete, perfect fit , not a flat one so can take spillages. But I’m mibbe a wee bit far away to pop round for a brew though |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 911 ![]() ![]() |
If you want to keep the boot clean, this is by far the best on the market.... |
Cheers guys and thanks for the offer Mr Tee, it is a bit far..!
