![]() | Home > Maintenance & Mods (L322) > What a silly place to put a reversing camera |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
I agree. There is a retrofit camera available which fits in the upper tailgate, replacing the rubber button to open it with a new one which incorporates a camera. It can be hooked up to the existing camera wiring.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
I mounted a camera next to the upper tailgate release switch. The camera is at an angle (45 deg?) to its flat base that attaches using 2 very small screws into the soft plastic beside the release switch. I built a switch box that uses relays to switch between the surround camera input or the tow-ball camera or the caravan's rear camera using a 3-posn rocker switch mounted in the top of 1 side of the cup-holders that is covered by the cup-holder cover when closed. The cameras need to be PAL. |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Do you have a link to any by any chance please ? I agree about sticking to PAL - there are good reasons why people in the TV industry refer to NTSC as "Not The Same Colour". |
https://www.gooutdoors.co.uk/15906321/falc...a-15906321
Thanks Gary. |
Diydave Member Since: 15 May 2022 Location: East Yorkshire Posts: 5 ![]() ![]() ![]() |
Some great info guys, really apreciate your responses, Ive ordered a Trunk switch / camera. I do like the idea of switching between the camera's |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
Perhaps too late:
Vehicles with surround cameras don't use the same reversing camera as non-surround systems. |
