![]() | Home > Technical (L322) > L322 MY12 Rear Suspension Feels Strange |
Check the height sensors are free to move at both ends, Active damping relies upon rate of change (amongst other things) as well as relative position of the height sensors to determine the amount of current that should be applied to each damper. |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I had an unstable rear on my car. In my case it was a rear strut that was shot (no oil).
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Thanks for this; mine feels similar, especially when cornering at speed, for example, on a motorway curved slip road (think continental style tight curved types). Did yours do the same, also any evidence of rear strut leakage? |
Is there a method to checking free movement? |
I don’t have many of those in this part of Lincolnshire ![]() I would get it even at 30-40 mph… But mine was bad…
Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Any recommendations on replacement suppliers? They are rather expensive from LR and the cheapest are about £310 for Chinese versions on eBay which look identical but longevity may be an issue. |
The RR Bandit Member Since: 31 Oct 2019 Location: Teesside Posts: 29 ![]() ![]() ![]() |
I bought a pair of OEM ones off Island 4x4 a few years back for approx £520 & I’m sure they’re cheaper now 2011 RR Vogue 4.4 TDV8 |
https://www.island-4x4.co.uk/suspension-pa...mp;sort=3a
Thanks for that. Island 4X4 are definitely the cheapest for Bilstein which I'm sure have got to be better than the cheap Chinese variants on eBay.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1295 ![]() ![]() ![]() |
Really easy to do. Fold the rear seats forward and remove the boot floor and you will see three 13mm nuts. Remove the active suspension connector and remove the nuts. Remove shock lower bolt and it slides out. Handy to have a jack under the knuckle to adjust the height to get the bolt out/install. Just had mine out to do a suspension refurb. |
Thanks good to know. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
The Workshop Manual is downloadable from the Wiki. All in there.
Thanks, good point about the seal, although would a smear of decent instant gasket do the trick? |
