Home > Technical (L322) > L322 MY12 Rear Suspension Feels Strange
mjdronfield
They are fairly cheap from the dealer, I didn’t consider alternatives.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #646536 25th Oct 2022 7:57pm
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
I replaced mine about six months ago, the large patch of oil on the drive gave away the leaking damper.
You can check by removing the bottom bolt and feeling the resistance of the damper it only takes a few minutes but as someone said you need a jack to support lower wishbone to get bolt out and back in as the airbag acts against you.
I got mine for Island 4x4, they are sided but its obvious when you compare them.
I changed mine on my own but you do need long arms to reach inside the rear door to get the first bolt on. L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #646543 25th Oct 2022 8:29pm
