Home > Technical (L322) > Thule roof bar feet help-I think I must be thick.
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I promise I have used the search function, but the results just seem to get me more confused.
I have a set of Thule aero roof bars, that I used on my D4. However, how do I attach them to my 2006 L322?
The bars have those rubber srtips that wrap around rof rails on the D4, all very easy.
So I am assuming that I need some feet that go into the roof where those flappy bits lift up-BUT, the websites that I have looked at say they have nothing for my car Question
So, are there feet that available? If so, which ones?
Post #646310 23rd Oct 2022 4:23pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
On my Thule roof bars the feet wrap around the door shut and then clamp in place so can only be removed when the doors are open.
I think you can change the feet to ones compatible with the L322 easily as long as the cross bars are long enough.
Not sure if they did a version that connects to the roof channels (with flaps raised) or roof bars (if fitted). Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #646321 23rd Oct 2022 5:49pm
philip1972
Thank you. The ones that clamp the roof above the doors will solve the problem, and I hadn't thought of those.
Post #646514 25th Oct 2022 6:12pm
I don't know whether they are still available, but a few part numbers on this thread
Post #646522 25th Oct 2022 6:47pm
Westminster_Bri
I have a hunch that Thule have stopped production of the correct feet... Sad
Post #646927 31st Oct 2022 9:56am
Weegie
Are the bars adjustable for width? If so you may have to get LR rails which attach under the “flappy bits” and then the bars clamp to them. If I understood correctly.
Not cheap but you might find someone on here who has a pair they want to sell. John
GAP iiD BT-Sold
Post #646928 31st Oct 2022 10:17am
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Have you tried the Roof Bar Company website?
Post #647033 1st Nov 2022 7:46am
