Home > Technical (L322) > Range Rover 3.6 fault codes
Adi322
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Thanks GaryRR
Battery is new and alternator is charging ok have checked all the connections under the bonnet but havent found any signs of corrosion. Bit lost now
Thanks
Adi
Post #646110 21st Oct 2022 1:45pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
@ mikey im getting much the same several error codes some relating to fuel pump and fuel pressure sensor ,was going to try the forte cleaner and 2 stroke oil ,just wondering how much 2 stroke oil to use ? thanks mark
Post #650698 14th Dec 2022 3:15am
Adi322
Had all of the above and finally changed the sensor on the rail and all th codes disappeared. Finally fixed I thought now a month later same thing all over again. Tried another new sensor but it faults still there. I would be interested to know how much 2 stroke to use as well before I change anything else
Adi
Post #653590 14th Jan 2023 6:41pm
