Home > My Range Rover > Back with another Supercharged
Page 51 of 58 <123 ... 505152 ... 565758>
Superspoons
Hi David,
Can you post a link to the oil your using from Smith & Allen please ? I need to do mine this week.
Thanks
Gavin Gavin
Post #645845 18th Oct 2022 6:51am
dingg1
It would only be black after 100 miles on a diesel, that oil is very dark imo for a petrol engined car after a relatively low mileage.... I'd expect the next change to be a lot clearer if its not I'd be a bit concerned...
Post #645854 18th Oct 2022 8:42am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
yeah a few regular oil changes will see that clear up a bit. dont forget i know the heads have been done but there will be plenty of crud that the fresh oil will be lifting off. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #645895 18th Oct 2022 5:10pm
dhallworth
I’d expect diesel oil to be black after 500 miles, petrol oil I’d expect to still be golden after 500 miles.
I’m going to check it again in about 500 miles and if it’s not golden then I’ll change it.
This is the oil that I use - https://www.smithandallan.com/product/smit...e-oil-4140
Post #645902 18th Oct 2022 6:33pm
Phoenix
I wouldn't be too concerned - the block has essentially been open to the elements for a good while and with the changes in temperature and humidity there will be lots of little bits of corrosion forming - which the heat has lifted off the surface and dropped into the oil, the oil pump has then done a fine job of reducing it to sub-micron particles which are now attached to the oil molecules. It may take another oil & filter change to get it all out but if there's no significant silvery bits in the filter or drained oil (I'd expect some, TBH, given what you've replaced) on the next change, then it's nothing to worry about.
Post #645939 19th Oct 2022 9:33am
Superspoons
David.
Thanks David - 10 litres ordered along with a genuine filter Gavin
Post #645946 19th Oct 2022 11:14am
dhallworth
We made it 6 weeks without a fault which given the amount of work done and the amount of things taken apart and put back together again, I’m quite happy with!
Climbed in it today to go and fetch the other L322 from the detailer and the dashboard pinged with a message telling me to remove obstacles and reset height. Every time I tried the back didn’t move and the front went to extended height.
It’s sitting like this tonight.
The 4x4 Info screen shows the rear left sensor flashing with a red line and being out of sync.
There’s no faults logged on the ECU but the heights show the left hand rear as being way above the others height wise.
Going to get it back inside once I’ve finished tinkering with the P38 and check the connections to the height sensor but it looks like I’ve got a sensor that’s gone south.
At least it’s an easy enough fix.
Post #646210 22nd Oct 2022 4:39pm
Phoenix
Does the reading change at all? it may just be a seized / detached linkage.
Post #646211 22nd Oct 2022 4:55pm
dhallworth
I’ve not had a proper look at it tbh.
I’m not sure it’ll be seized as they were removed when the subframe was blasted, cleaned, lubricated and refitted.
Although it’s a Range Rover so nothing would surprise me.
Post #646212 22nd Oct 2022 4:58pm
MonteCarlo
What a saga, read this thread from cover to cover the dedication is immense, gives me inspiration to finish off my P38
Talking of P38's how is your VSE doing? MY2001 Range Rover P38 Vogue 4.6
MY2005 Jaguar S type 3.0 SE
MY2000 Land Rover Discovery II TD5
MY1987 Bentley Turbo R "project"
MY1977 Rolls Royce Silver shadow. "project"
Post #646521 25th Oct 2022 5:40pm
dhallworth
The plug on the rear left height sensor was damaged when I went to unplug it and it was held together with a cable tie. I replaced the cable tie when I rebuilt it but hadn’t pulled the cable tie tight enough. I meant to try and get a plug and tails from a breaker so that I could repair it but forgot.
Anyway, I fixed this tonight Very Happy Squeezed the plug and it came back to life and levelled itself. Have pulled the zip tie tighter and will now look for a breaker to get a plug from.
I’m down to 1 VSE now and it’s doing great. I noticed that there was a bit of play in the steering on it in the summer and it annoyed me so I had the steering box rebuilt by a company in Birmingham. They rebuild them for Land Rover. I swapped that over and it was better but still not great so this weekend I replaced all the bushes on it too. I did the front and rear panhard rod and front radius arms with genuine Land Rover bushes. I didn’t do the rear radius arms as genuine ones aren’t available. I’ve just driven it out of the workshop tonight and it’s transformed the car. Thumbs Up
Post #646539 25th Oct 2022 7:01pm
Mikey
Big Cry
Assuming its the 322 were talking about, try YMQ503220
Repair kit available from JLR Thumbs Up
Post #646551 25th Oct 2022 8:30pm
dhallworth
Bow down Bow down Bow down
Thanks Mikey! I’ll give Rob a shout and get him to order me one up. Wish I’d looked into it before refitting the subframe now. Laughing
Post #646552 25th Oct 2022 8:49pm
Sandyt
Well Mr H surprised you are using a tie wrap to fix stuff Shocked there is a chance for the rest of us then Very Happy Glad you have it fixed
Also interesting on the p38 I am having similar steering issues need to get it in and sort it maybe this weekend
Post #646597 26th Oct 2022 6:26pm
dhallworth
Laughing Laughing Laughing Laughing
Only because I forgot to look for the plug and tails from a breaker. Glad I did now as Mikey posted the part number above for the repair kit!
Post #646602 26th Oct 2022 7:21pm
