Home > In Car Electronics (L322) > Can't Locate a Medium Speed Can Bus Fault - 2010 L322 |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 301 |
This one is quite bizarre. 2010 L322.
8th Sep 2022 5:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
have a look in the rear near side cubby...thats where all the 'tech' is and i suspect a loose cable/connector/unit might be the cause. ... - .- -.
8th Sep 2022 5:23pm |
I'm going to update the topic here till I've cured this in case it helps someone else in the future.
14th Sep 2022 5:06pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Hope they find it, keep us posted.. Pete
14th Sep 2022 5:14pm |
Something I was going to mention, the method for starting a 2010 L322 that says "smart key not found".
14th Sep 2022 9:40pm |
Sounds like you are at least getting somewhere with it.
14th Sep 2022 9:57pm |
Yes, that's the position.
14th Sep 2022 10:05pm |
I'm back with a little more info (and an updated title to help others in the future) hoping one of you knowledgeable chaps might be able to shed some light on this.
17th Oct 2022 4:46pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
According to the medium speed canbus network diagram, there are only 2 connectors which can interrupt the network. They are for the drivers and passengers door modules. I suggest concentrating on those 2 connectors.
17th Oct 2022 8:26pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Also bear in mind that MS-CAN (although actually 'low speed' within the CAN specification) will operate with only one 'leg' of the pair functional - and not throw a DTC, so if you are having lost comms on the connection, then it will be on both lines, not just one.
19th Oct 2022 9:43am |
Well, I've officially given up.
22nd Oct 2022 5:25pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
HI, I have had a similar fault on our FL2 2008 after I put a new engine in it. The original engine appeared to be seized, so after much flaffing about after the local mobile mechaic gave up and doesn't talk to me now, I bought an engine off of a decent breaker. As the engine is out of a later model, I swapped the engine looms over. All the sensors appeared to be the same part number, but I later found the Sump level and temperature sensor is wired differently. The engine still would not start after refitting the engine! Lots of fault codes, and the Lin bus was down. Previously the engine loom had a broken wire where it crosses the nearside inner wing. I thought at first it was another wiring loom fault. Then rechecked the ECU connections for bent pins. After much thought, I took out the Starter Motor, and found the solenoid had jammed when trying to start. So, I got a guaranteed good second hand motor with guarantee and fitted it. The engine started first turn!. THe teory now is that with a low battery, the starter failed to complete the computer self check and went on strike. I also changed the Starter Relay as well, as I had one suspecting that a contact might be burnt. Like you I first looked at the key module, door locks, but as always its something so simple it makes you want to kick the cat ( I don't have one). Thats why I bought my L322 as I like Rangerovers, and the last one I had was a P38, which died on me, as it did not like its gas conversion.
22nd Oct 2022 6:34pm |
I've picked it up from the garage now. It lasted about three miles till it went back into restricted performance.
27th Oct 2022 4:10pm |
Hi, this a long shot, but, A worn or faulty clockspring in the steering column can have this fault appear. Your first clue was turning right. I have seen this as a solution on other forums. Try resetting the Steering Angle sensor using Diagnostics. It works with an Autel AP200 Maxi app on my phone with the Land rover add-on. Buy it on the Play Store, or direct for the dongle. When §i recently had faults on our other Freelander 2, which has virtually the same basic coding, I found it would read all the door locks, infortainment system, dashboard, etc. I also used it to program the keys. When I changed a front wishbone, I had to reset the Steering Angle Sensor. I have also discovered that the low voltage message can mean that the main key needs a new battery, not the vehicle battery. Another common fault is the Orange fibre optic cables into the rear fuse box having corroded terminals. Landrover do a repair kit for this one. Hope you fix it, as you obviously like the car.
27th Oct 2022 5:29pm |
