![]() | Home > In Car Electronics (L322) > Can't Locate a Medium Speed Can Bus Fault - 2010 L322 |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 367 ![]() ![]() ![]() |
Interesting pointers, thanks. And I'd forgotten about High Peak. I'll give him a call tomorrow. Edit: It seems High peak 4x4 has closed down according to Google. But the search threw up Hallam Bros who I will ask.
biggles3124 Member Since: 03 Mar 2012 Location: Andover, Hants Posts: 103 ![]() ![]() ![]() |
Just too throw my two pennoth into arena!
I collected it from the garage with a view to PXing or selling it this next week.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
If you had a tool capable of reading and clearing fault codes you would be able to clear the codes yourself then check again as soon as the fault occurred.
I've had it in the indy as its done it but it throws up too many faults.
Maybe worth removing the footwell side panels to wriggle the wiring and connectors behind them. The panels are easy to remove. |
The indy spent three weeks poking around everywhere, they were at the point of removing the dash.
