Home > Technical (L322) > TD6 Leak off test |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Have you checked for a binding brake? Fairly common problem that gives vibration like you describe. It did on mine once over. |
15th Oct 2022 9:08am |
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 |
Yes I actually read your posts about it, the wheel doesn't seem to be hot after a spin. Although it was a month or so ago I checked it. I will check it again for peace of mind.
15th Oct 2022 10:02am |
Felt the wheels today after a spin and there was no heat at all, even the calipers felt cool which I thought was odd, so id say its not a sticking caliper. |
15th Oct 2022 5:50pm |
Well that is one item less to worry about. |
15th Oct 2022 5:53pm |
I know this is a shot in the dark, but do the wheels sit flush on to the brake disc on the L322.?
17th Oct 2022 7:01pm |
The wheels centre themselves on the raised spigot on the hub.
17th Oct 2022 7:34pm |
I suppose it could move about depending on how snug the wheel fits on the spiggot. Either way its not good is it.
18th Oct 2022 12:06pm |
Is it possible a dirty fuel filter could be my cause.?
26th Oct 2022 12:39pm |
