Home > Technical (L322) > 4.4 TDV8 viscous fan
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Morning All i have a clicking on start up and after replacing everything connected to the aux belts its still there but only when cold, ive done some research and things may be pointing to the viscous fan, in the morning when cold there is a loud ticking but the loud roar has gone also when the engine is upto operating temp you can feely spin the fan there is a little resistance but not much.
What i intend to do is remove the fan from its spindle and rest it in the cowl and then when the engine is cold start i up and if the clicking has gone its definitely the fan, my question is due to this being part electric and viscous will it be ok to do this as i dont know if the fan has an electric motor built in or if its a form of clutch that engages, as it spins up on tickover when the AC is on 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #645549 14th Oct 2022 6:28am
kevinp
I think it just has electric engagement, no electric motor. I'd be inclined to disconnect the multiplug just to be safe.
I think other people have reported a 'clicking' when the water pump was on it's way out.
Post #645556 14th Oct 2022 8:39am
Furnitureman
I had a clicking that was constant new water pump fitted all gone so now onto fan to rule that out 2012 Range Rover Westminster 4.4 TDV8
Post #645568 14th Oct 2022 11:27am
garyRR
Clicking on the 4.4 TDV8 whilst it's warming up, coming from the viscous fan coupling, is entirely normal and nothing to be worried about.
A constant noise, once up to temperature, is something to investigate. 2015 Range Rover Autobiography 4.4 SDV8
Post #645572 14th Oct 2022 11:54am
pcourtney
my clicking seems to be louder now than what it was in the summer months, but is does ebb away when engine is warm, or after I have driven for ten minutes and park up - I have a quick listen before I turn off the engine,
am keeping an eye on it, just in case the water pump is on its way out Sad
Post #645576 14th Oct 2022 12:47pm
Furnitureman
This is more thank clicking its v noisy
Post #645594 14th Oct 2022 3:14pm
