Home > Technical (L322) > Gap IId Transfer Case Low/High Live data vs Engine Input |
jriedel Member Since: 14 Oct 2022 Location: Montana Posts: 8 |
Hi all, i have a question on Transfer Case live data that is available on the GAP IId Diag tool. The tool is plugged into an O7 RR L322 SC. Here is the punch line, if i am interprting the live data correctly, the engine thinks the Transfer box is in Low while the transfer box thinks it is in high. If this is the case, it adds a piece of data to the RR being in Limp Mode, assuming i am interpreting them correctly. See below
14th Oct 2022 3:04am |
I corrected a typo above, it is now correct, the engine reports high when transfer reports low, and reports low when transfer reports high. |
14th Oct 2022 6:40am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
If your IIDtool isn't at the latest level then best to update it in case a bug has been corrected, but comparing with the same logging done on another vehicle would seem appropriate.
14th Oct 2022 7:44am |
I would love to see what another RR show for these same live values.
14th Oct 2022 1:44pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 748 |
Is there a clue with the car's behaviour?
14th Oct 2022 3:49pm |
DTCs... I thought you would never ask
14th Oct 2022 6:10pm |
There appears to be a power supply issue with the PCM, possibly a short circuit on a sensor 5V supply. I would check the wiring to all the listed sensors looking for chafing. |
14th Oct 2022 7:58pm |
Sounds like a good project for tonight, thanks for the advice. I'll let circle back with what i find. |
14th Oct 2022 10:39pm |
Started checking the things that are connected to the PCM that threw codes Ebox related Code 1)Tested to the connections to the ebox fan. 2)Removed the ebox fan and bench tested it at 12.6 VDC. It sounds fine and it draws about 150 - 200 mA when running. Throttle body - Forced shutdown Code 1) Backprobed Throttle body connector: Checked 5 volt reference signal to ground, yes it is 5 vDC 2) Backprobed Throttle body connector: while vehicle is Idling, Measured Sensor 1 voltage at 0.85 VDC, measured sensor 2 voltage at 1.7 VDC. 3) Connected throttle body to an external 5 VDC power supply, rotated butteryfly to see if voltage changed. It does, but i am not sure if it is changing like it is "supposed to". From closed to vertical, voltage goes from 0.85 to 4, and 1.7 to 4.3 on position sensor 1 and 2 respectively. 4) Measured resistances across position sensors as I rotated buttery fly in throttle body. Oddly, the resistances don't change (i figured they would, since my understanding is they are potentiometers). The image below shows the resistance values that I measure.
I am going to post this throttle body info/questions in a new post. |
17th Oct 2022 1:50pm |
