![]() | Home > Maintenance & Mods (L322) > Speedo intermittent after engine bay soaked-l322 4.4 petrol |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7857 ![]() ![]() ![]() |
All I know about the speedo is that it’s fed from the rear left ABS signal. The reluctor ring broke when I had my TD6 and the speedo didn’t work at all. Trouble then was, the car thought it was stationary so if you tried to drive, it got the speed signal from the other 3 wheels so thought they were spinning… and applied traction control.
Boobardoodles Member Since: 15 Jun 2022 Location: Wirral Posts: 10 ![]() ![]() ![]() |
When you say strange things, would this include hesitating when you put your foot down, ie it starts to move for a brief moment, then pauses for a second or so, then accelerates, not sure if speedo is working as am too busy wondering if I will make it across the junction or not. It doesnt happen very often but can be very scary or annoying at times? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
Get the codes read, there should be one if the ABS sensor is faulty, it could just be a coincidence with the water issue.... or not... |
Yes, it thinks the car is stationary if the speedo reading is zero, but it’s getting wheel speed inputs, so as far as the car is concerned, they must be spinning if the car is stationary…. So it activates traction control and then winds the power back. When mine did it, I had throttle to floor and it hardly moved (or revved).
